Manual window conversion help
  • chrisesteschiro
    • 361
    88 325is
    My drivers power window keeps popping the fuse and I have replaced the window motor, switches, and harness. I give up.
    What do I need to do to convert to a manual window? Do I need different glass?
    Any help would be appreciated. I searched without any clear answers.
  • SmokeE30
    • 1730
    You need the regulators off an 84-85 manual window car. And if you don't have a acces hole for them you would have to swap door cards or cut the holes your self as late models didn't come with them
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • chrisesteschiro
      • 361
      All I need is the regulators and handles? If this is true thats great news!!!
      • SmokeE30
        • 1730
        I believe that's all you need but I haven't done it personally I do know I'd like to at some point and tracking down the manual regulators isn't getting any easier
        Bimmerbuddies LLC
        717-388-1256
        • fronton
          • Oct 2009
          • 1262
          yes, I have done it. As long as you have early model windows, manual regulators are plug and play.
          • lowsodium
            • Dec 2012
            • 289
            I wish I could find a nice set of manual regulators for a 4 door car in good shape. Nearly impossible to find.
            Haven't you ever seen Russian Nesting Dolls? They work like that.
            1987 325e / 2008 135i
            • IronFreak
              • Dec 2012
              • 3702
              what about late model 88' conversion?
              Instagram @rebellionforge
              • fronton
                • Oct 2009
                • 1262
                If your late 88 has scissor style regulators, I believe you need to get early model glass to go with early model regulators. I don't know if there is such thing as late model manual regulators unless Europe still considered power an option that late.
                • chrisesteschiro
                  • 361
                  My car is a steel bumper 88 but it has scissor window lifts so I need the entire mechanism and glass I suppose.
                  • LivingLegend06
                    • Dec 2006
                    • 1604
                    I have a door from an 88 and it still has the early style regulators? Running the VIN verified it as an 88 model year.
                    • fronton
                      • Oct 2009
                      • 1262
                      I think the switch from early to late is 8/87 build date.
                      • dsobering47
                        • Oct 2007
                        • 697
                        I did the manual crank conversion on my car with late model window glass. Made an "L" or hockey-stick-shaped bracket to convert the glass to bolt to the regulators. Took prob 2 hours.
                        • lowsodium
                          • Dec 2012
                          • 289
                          Newer style glass AND regulators?
