omfg.... some people jeeeesus
  • CleanAzzE30z
    • Jan 2004
    • 11794
    Originally posted by thejimlab
    someone's going to die.
    hahaha!!
    Mariano
    • 92 mtechnic cabrio
      • 4907
      don't be mad guys, that's what I did while I was looking for spacers.
      let me tell you one thing.
      you can drift better.
      :zzz:
      okay, on a serious note. I don't think they put an E46 front valence on, on purpose. I seriously think they thought that it was the right valence for that model.
      I'm sure the car would look good from say.............ten miles away
      R.I.P 07/01/09 - 04/23/10 :(
      • h0lmes
        :zzz:
        I don't think that e36's look good from any distance. To me it's just the bastard child of an e30 and an e46.
        • bmwmike
          • Sep 2004
          • 561
          washer wheel spacers = certain death
          www.rimstrader.com
          all the parts you need to swap the M30 into your E30 here-> http://www.r3vlimited.com/board/show...ght=m30+mounts
          99 540i/66 911
          • kowalski
            • Jan 2005
            • 1791
            Originally posted by bmwmike
            washer wheel spacers = certain death.
            + 1,000 for both
            • BMWguy
              • Jan 2004
              • 482
              Why? Not that I would do it... but I dont understand why it is certain death... please elaborate...
              • redhatpat
                • Aug 2005
                • 656
                Washers don't have a uniform flat surface and aren't intended to hold a certain measure of torque when stacked up like they are in the pic. What that means is they will shift, loosen, and eventually the wheel will/can come off. Also they look like regular hardware washers. These always have some variation in thickness so there's no way the wheel is sitting flat relative to the hub.
                Not good.
                • C ///M
                  • 1040
                  Any of you guys notice the huge difference in fender gap when comparing the left and right front wheels/fenders. One side has like a 2 inch gap between the fender lip and the tire, the other side has absolutely no gap.
                  -"spacers"
                  -lob-sided car/stance
                  -wrong bumper cover
                  -awful fitment
                  -incomplete assembly
                  -no paint
                  -still damaged front driver door
                  That car must be awesome to drive. $8k.. I'm as speechless as the next guy.
                  332iS R.I.P.
                  • blitzkreigm3
                    • Feb 2006
                    • 12
                    simply unfunking believeable-"the ultimate killing machine"
                    what do you suppose holds the rear trailing arm on bubble gum!!!
                    • rward325
                      • 251
                      The spray painted hood doesn't excit eme either. For $8k you have to be an uneducated idiot cuaght up in the moment of the suaction like so many people on ebay do. As for the washers, That is jsut plain STUPID! Ther is no way any qualified repair shop would repar a car like that. This thing was butchered in someones backyard who didn't give a crap about anybodies safety in mind.
                      BTWE: You better be wearing those harnesses when the wheel falls off!
                      Just livin in the OC minus my E30
                      • bmwmike
                        • Sep 2004
                        • 561
                        pretty much what redhatpat said. Washers arent going to be very exact. And even if you put the same amount of washer on each lug (looks like about 10) some will end up being spaced a bit different. Basically the whole car probably shakes violently as the person drives, and eventually the washers will cause the bolts to come loose and wheels fall off. Ive seen a wheel come off a car because of an actual wheel spacer, I couldnt imagine using washers from menards..
                        www.rimstrader.com
                        99 540i/66 911
                        • Digitalwave
                          is a poseur
                          • 6287
                          I guarantee you it was because of improper torqueing and not because of the spacer.
                          RISING EDGE
                          • CleanAzzE30z
                            • Jan 2004
                            • 11794
                            amen.
                            • sticksdaman
                              • Apr 2005
                              • 2987
                              on the brightside i found a new sigline:
                              Originally posted by ebelements
                              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                              • BMWguy
                                • Jan 2004
                                • 482
                                ofcourse... I guess I wasn't thinking about the centrifical torque put on wheels... or the fact that washers aren't perfectly flat or all even... thanks for the clarification...
                                Lets call that one a brain fart!
