Head Removal DIY?
  • raleigh29
    • Apr 2009
    • 93
    Head Removal DIY?
    I have been doing some searching but haven't found anything.
    Is there a 6cyl head removal DIY out there?
    03 M3 Vert
    89 325i
  • jaywood
    • Jul 2010
    • 4528
    The Bentley manual has a diy in it
    • SmokeE30
      • 1730
      It's a pretty straight forward job just disconnect everything under the intake manifold and remove with the intake and exhaust manifolds still attached is the easiest way I have found, although its a bit heavier that way so an extra had to lift it is nice
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • Gary Horneck
        • May 2011
        • 435
        http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
        2011 335i/1995 Mercedes C220 (rallyx)
        • Unearth078
          • May 2008
          • 2623
          not to be that guy, but i would not tackle this project with out... the spiral pattern applies even for removing the head bolts.
          Originally posted by Lof8
          4 doors allow you to transport more whores.
          therefore, their value is much greater.
          Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
          • enigmaticdream
            • Jan 2010
            • 572
            1. Drain coolant
            2. Drain oil
            3. Disconnect mid-pipe from exhaust manifold OR ignore and just remove the exhaust manifold from the head (6 nuts)
            4. Remove exhaust manifolds (12 nuts iirc)
            5. Remove fuel rail from intake manifold.
            6. Remove AFM, throttle body (4 bolts iirc), and intake manifold (12 nuts iirc)
            7. Remove coolant hose on the back of the head.
            8. TDC the motor
            9. Remove all belts, including timing belt.
            10. Remove valve cover and head bolts.
            That's roughly what you need to do. You'll need 10-13mm sockets, swivels, extensions, and potentially heat for the exhaust nuts. Prep to replace exhaust and intake studs. You'll need new exhaust gasket, intake gaskets, throttle body gaskets, timing belt (just do it now anyway...). I'd also suggest replacing hoses under the intake manifold while you're there.
            For the "bitch hose" under the intake manifold, a zip tie works well in hold it down until you get the intake on.
            1986 911 Supercharged Frakenstrat/Stripped
            1987 325is Delphin/Black (Olga)
            1988 M3 Zinno/Natur (Elsa)
            Manual or STFU
            E30 Chapter of BMW Car Club of America
            E30 Oktoberfest 2017
            • enigmaticdream
              • Jan 2010
              • 572
              If you're going to strip the head, use this...
              Manual or STFU
              • kickinindian
                • 2327
                i came in here expecting head from body removal...i am disappoint:(
                • e30strokr
                  • 211
                  TDC, a torque wrench and removal/installation of headbolts is the key !!!!! ... like he said its easier to remove the head/manifold/fuel rail together.. dont forget to indentify the hoses/ wires... while it looks easy to remember you'll be glad when it comes back to putting it all back together.... did I mention TDC? just a reminder.. dont ask why haha
                  • Cletonius
                    • 2809
                    +1000 on TDC. Mark the cam also so if it moves you'll be able to line it back up.
                    It's ridiculous trying to remove the intake and exhaust manifolds on the car. Just do the head bolts and lift the whole thing off at once. Pull the manifolds and everything on the bench.
                    - Josh
                    1990 325is
                    Need a shift boot?
                    Looking to buy shift boot frames, PM if you have one to sell
                    Here's what happens when you let the internet pick your license plate
                    • AwakenNoMore
                      • Dec 2010
                      • 1291
                      With no previous internal engine experience equipped with basic tools and a downloaded Bentley manual I was able to do it with ease. My advice to you:
                      Do as much preventative maintenance as possible.
                      Have the head checked and skimmed.
                      Avoid Victor Reinz head gasket (I went Goatze)
                      Clean the head bolt holes out REALLY good, I spent over an hour easily cleaning the holes out with brake cleaner, rubbing alcohol and endless Q-tips.
                      In the end the results are totally rewarding.
                      1991 325i - "Scambles" The Daily Driven lightly modded.
                      1988 Mazda RX-7 TII "Mako" The Free Dorito
                      bacon by Jared Laabs, on Flickr
