built m20, or m50 swap.
  • 87m50
    • Jan 2013
    • 35
    In a debate right now. I currently have a 87 with a m50 non vanos. but the chassis is pretty shitty and wiring on it is even worse. but im buying a 90 with a m20 in it Friday and I am debating on swapping my m50 and tranny over with a plug-to-plug wiring harness or buying a fully built m20... don't know which to do.
  • Killacortes
    • 1937
    Healthy m20>non vanos m50
    r3v does not fuck around. First you get banned, then they shoot you
    • SmokeE30
      • 1730
      Well how built is the m20 your buying? a good running m50 will be quicker than a stock rebuild m20. Now if the m20 has cam and head work and other supporting mods it can be quicker but do any of those mods I the m50 and it will walk the m20 again. You have the m50 swap already how much are you going to spend for a m20 that will make m50 power?
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • Wh33lhop
        • 11705
        Do you want power, or character? A built M20 will be cooler, likely more expensive (if you actually build it as opposed to a run of the mill 2.7i which isn't very quick), and have more character than an M50. If you want cheap power, go for an M50 and slap a tune and M3 cams in it later on down the line.
        paint sucks
        • 87m50
          • Jan 2013
          • 35
          the m20 is for sale on here actually, this is the mod list:Block has been bored to 84.48 and decked and hot tanked
          Head was fully rebuilt with new seals, decked, and refinished valves
          Micro polished crankshaft and camshaft
          MaxSil pistons and rings fitted to block
          Forged CX Racing H-Beam rods
          Reinz HG, VC gasket, oil pan gasket
          New bearings
          WoodGrain Valve Cover (:
          Metric Blue head bolts
          Long Tube headers with new gaskets
          NEW cps, dizz/rotor, thermostat/housing, coolant sensors, all new cooling hoses, rear main seal, aux seal, cam seal, crank seal, freeze plugs
          Rebuilt PS pump and new hoses
          All new belts
          NEW solid condor mounts for tranny and block
          NEW flame thrower ign coil
          NEW water pump
          NEW slave
          NEW flywheel bolts
          NEW (Upgrade/updated to metal) rear seal
          Cleaned and painted intake manifold with new gaskets
          NEW Sach's throwout and pilot
          Allllll mated to a 5spd Getrag 260 shifting in all gears smooth with a stage 2 eGay clutch!!!!!
          the m50 has shrick cam and tuned ecu. and yea I have the entire car that its in now and would just need to swap everything over and get a new brake booster. and if I don't do this im working a deal to trade my 87 with m50 for the motor so just some time meeting up in reality to do the trade.
          but ive never done a motor swap and don't know how much it would cost for someone to do the swap for me with m help.
          • bonobo
            • Jul 2012
            • 94
            After doing a full rebuild on my s50 before swapping it in, I can tell you that m20s are much easier to work on and cheaper to repair. The m20 is also a bit less weight over the front axle than the m50 will be. Obviously, if you want to haul as much ass as possible with the least amount of money possible, then m50 is the way to go, but I think you already knew that.
            1988 BMW 325 - S50B30US
            Instagram "Build Thread" - http://instagram.com/jfchiu
            • ak-
              • 12422
              Can you just build the m20 to show what those CXr h-beam rods can do lol.
              1991 325iS turbo
              • NeedaE30
                • 397
                m20 yes built m20
                  • 37832
                  :up:
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    Given the options above, and what you have to work with, I'm going to throw my vote in with M...............60 swap.
                    But really, M50NV is a turdburgaler.
                    As much as I hate to say it......ugh, this hurts.....just go with the M20.
                    • lowsodium
                      • Dec 2012
                      • 289
                      Another vote for the M20. It fits better in the engine bay too, and will look stock.
                      Haven't you ever seen Russian Nesting Dolls? They work like that.
                      1987 325e / 2008 135i
                      • dannyyisntt
                        • 3141
                        M30 swap it
                        • mrmckie
                          • 728
                          all that and they used metric blues??.....:shock:
                          "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
                          1991 318is - the cruiser
                          1989 325i - the rats nest
                          • gtdragon980
                            • Jun 2008
                            • 1808
                            Originally posted by dannyyisntt
                            M30 swap it
                            This or m20 built & boosted. You will own the streets.
                            FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                            Originally posted by scabzzzz
                            I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                            1989 325i - Project/weekend driver
                            2002 325i - DD
                            2005 Suzuki SV650 - Toy
                            • N2MYE30
                              • Oct 2007
                              • 5536
                              Id say M20. I have both right now. My cabrio is an M20 and my coupe is an M50NV. The M50 gives me plenty of smiles per gallon but the M20 has grown on me these last few years. A clean M20 any day > M50. The only real power I have said "yes, now thats power" has been boosted. Let me just say that both cars run flawlessly so not electrical/mechanical demons to taint my choice.
                              COTM
