built m20, or m50 swap.
  • SmokeE30
    • 1730
    Originally posted by 87m50
    the m20 is for sale on here actually, this is the mod list:Block has been bored to 84.48 and decked and hot tanked
    Head was fully rebuilt with new seals, decked, and refinished valves
    Micro polished crankshaft and camshaft
    MaxSil pistons and rings fitted to block
    Forged CX Racing H-Beam rods
    Reinz HG, VC gasket, oil pan gasket
    New bearings
    WoodGrain Valve Cover (:
    Metric Blue head bolts
    Long Tube headers with new gaskets
    NEW cps, dizz/rotor, thermostat/housing, coolant sensors, all new cooling hoses, rear main seal, aux seal, cam seal, crank seal, freeze plugs
    Rebuilt PS pump and new hoses
    All new belts
    NEW solid condor mounts for tranny and block
    NEW flame thrower ign coil
    NEW water pump
    NEW slave
    NEW flywheel bolts
    NEW (Upgrade/updated to metal) rear seal
    Cleaned and painted intake manifold with new gaskets
    NEW Sach's throwout and pilot
    Allllll mated to a 5spd Getrag 260 shifting in all gears smooth with a stage 2 eGay clutch!!!!!
    the m50 has shrick cam and tuned ecu. and yea I have the entire car that its in now and would just need to swap everything over and get a new brake booster. and if I don't do this im working a deal to trade my 87 with m50 for the motor so just some time meeting up in reality to do the trade.
    but ive never done a motor swap and don't know how much it would cost for someone to do the swap for me with m help.
    Seems like somebody built that m20 for boost, I would check what compression it's running now, but assuming its low for boost the cammed m50 will probably pull harder. I love the m20 the sound the reliably yet and ease of maintenance are all great but I wouldn't want to dump a bunch of money into an NA one. Now if you wanna boost it...
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • 87m50
      • Jan 2013
      • 35
      Its definitely built for boost, and I will be doing that down the road, but not yet, tleaning hard towards m20
      • Vtec?lol
        • Dec 2009
        • 3278
        M20 or bust. All that m50 bs is for the birds. If you're going to go 24v, do an s50 or better.
          • 37833
          You sir are correct and on par.
          Grover Beach, California
          BimmerHeads.com
          • wannaBMthree
            • Apr 2007
            • 601
            That said, the m50NV is good for boost
            • AdironRider
              • Dec 2004
              • 3491
              If you need this to be reliable, Id stick with the built M20. I prefer them anyways, but if you need to count on this car, Id stick with motors that plug and play more.
              Back to my roots
                • 34844
                how is it better than any other engine? such as an M52?
                • Cletonius
                  • 2809
                  Stick with the M20.
                  Any well done swap will be just as reliable as if it had come that way. Problems only happen when people cut corners or don't read all the wiring schematics before starting. I did a turbo motor swap in my k car in a weekend, I built the harness and prepped everything for months beforehand so it would be a one shot deal. My buddy drove that car for 4 years after I sold it to him 3 years after doing the swap. Never any problems with the swap... There are tons of clean E30 swaps done here too, plenty that aren't but that's another topic.
                  - Josh
                  1990 325is
                  Need a shift boot?
                  Looking to buy shift boot frames, PM if you have one to sell
                  Here's what happens when you let the internet pick your license plate
                  • totheredline
                    • Jun 2013
                    • 762
                    S54B32....
                    = Heidi 1988 325 -> 335i. 7200rpm built M30
                      • 34844
                      Originally posted by totheredline
                      S54B32....
                      werd :D
                      • Myster-E
                        Performance
                        • 552
                        12 valves, that's all you need. ;)
                        1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                        Visit www.BimmerHeads.com for all of your 12 valve needs!
                        • M3TROY
                          • Apr 2006
                          • 578
                          +1 m50 stock is pointless of your going for power as its just barly quicker than the m20.
                          the big advantage is in the gas mileage but other then that....nada.
                          if your looking to mode then just do S50 from the jump it will be cheaper and less work then m50 with m3 cams and a tune and it will still have more power.
                          • PeteD
                            • 982
                            These are my favorite threads. I love a nicely built m20. I have non vanos M50 (3.0 liter though) and it's a great combination of nostalgia and 24 valves. Built m20 > stock m50
                            • lambo
                              Captain Scene Points
                              • 10953
                              As much as I hate to say it......ugh, this hurts.....just go with the M20.
                              I never thought I'd see this day...
