Can I fit an m20 in the back of my e30?
  • TehRaydarlover
    • Mar 2013
    • 544
    Just bought an m20 :). Does not come with a head. Think it will fit in the trunk? Would it be safe for a 60 mile drive?
    Edit: maybe not the right place for this. Move if you feel it necessary.
    Build Thread
    Rear Diff Rebuild
    Rebuildable Viscous Coupling
    Transfer Case Rebuild
    "Life is simpler with 12 valves"
  • e30jake
    • Feb 2012
    • 855
    I don't know from experience, but I saw a picture on here at some point of an m50 in a trunk, so I'm guessing it would fit
    What it feels like owning an e30:
    88 325 S50 swap in progress
    90 325ix
    • TehRaydarlover
      • Mar 2013
      • 544
      Alright, forgot to say it came with steering rack oil pan front diff (ix m20) all the pulleys. Everything is still together now. Will probably have to do some disassembly.
      Build Thread
      Rear Diff Rebuild
      • xAZxE30x
        • 1241
        ha yeah take it apart!
        I have fit my block in no worries but with arm mounts and accessories you may have difficulty
          • 37829
          It will easily go in there.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • gath
            • 577
            It will fit, but the best way to fit it is to take the motor mounts off and loosen the dip stick so that you can move it around without hitting the trunk lid. I did it while the oil pan was on and no head. 60 miles is easy and it's a small load for an e30.
            • TehRaydarlover
              • Mar 2013
              • 544
              Here is a crappy pic of it. Any special tools I should bring along it tear it down? Will my 154pic craftsman socket set do the job?
              Build Thread
              Rear Diff Rebuild
              • QUKBMER
                • 8178
                It will fit no problem bro.;) Ive done it before. lol Just make sure it drained of all fluids completely.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Too bad you don't have a 'vert.
                  • TehRaydarlover
                    • Mar 2013
                    • 544
                    lol yeah I plan on bringing a tarp and lots of garbage bags for the parts.
                    This is going to be funny, I'll be showing up to Vintagefest in Chicago with an m20 in the trunk
                    Build Thread
                    Rear Diff Rebuild
                    • Thizzelle
                      • 4422
                      that's what she said
                      "I wanna see da boat movie"
                      "I got a tree on my house"
                      • naplesE30
                        • Nov 2007
                        • 1839
                        Pull passenger seat, insert m20,,, mid engine e30
                        • downforce22
                          • Aug 2009
                          • 3192
                          the ix m20 might not fit depending if you have the front diff and motor mounts bolted up. I guess you could take out the passenger seat and put down some tarps/ mats and put it in the passenger seat spot
                          • efficient
                            • Feb 2012
                            • 3312
                            just be careful with turns dips and bumps. sometimes you'll feel the car moving to one side depending on the turns and on dips or bumps it'll go down bad.
                            • TehRaydarlover
                              • Mar 2013
                              • 544
                              Were people able to get the trunk closed with it in there? Have it laid down on its side? Went out and did some looking at my trunk and engine, the front diff comes down about level with the oil pan. If I take off the motor mounts and other accessories then stuff it in head first I think I should be good to go.
                              Build Thread
                              Rear Diff Rebuild
