M42 in the trunk?
  • 2002maniac
    • 4260
    M42 in the trunk?
    I am driving to colorado to pick a motor and I would like to take my e30 rather than borrow a truck that gets 12mpg. I think if I pull the manifolds I should be able to lay it down in the trunk.
    Any tips for transporting a motor in your e30?
    Maybe I could remove my pass. seat for the trip and put the motor there...
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    Ive had an M10 in the trunk of my 2002, but as you know 02 trunks seem to be HUGE. If the manifolds were taken off though, I dont see why it wouldnt fit on its side. To be safer though and for the ease of putting it in and taking it out, I'd suggest taking the pass seat out and putting down plastic and cardboard and sort of put the engine there laying/sitting down however it will fit. Maybe some blocks of wood would help with that too.
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      I'd just do what justin said and put it where the pass seat goes with some cardboard/tarp. Then don't r3v.
      • ptownTSI
        • Jun 2005
        • 1265
        i would put it in the trunk. that thing is a flying problem if you wreck or someone hits you.
        • asubimmer
          • 6482
          fine put the seatbelt on it then :rofl:
          • redbull 325is
            • 7472
            i carried a volvo 240 motor in my 325is.. in the trunk w/ manifolds on.. but i had a bungee holding down the trunk lid.. can you yeeeeeeeehaaaaw.
            julien
            Build Threads:
            • Bill 84 318i
              • 1600
              I've had an m10 where the passenger seat goes and in the trunk at the same time - they both fit no problem (no manifolds or accessories...just the long blocks, and I left the oil pan on). Just make sure you put plenty of plastic down - it'll probably leak all over the place.
              It was the m10 under the hood that was hurting.
              • turnofftheradio
                • Apr 2005
                • 448
                I fit an m20 w/o manifolds no prob. makes me think an m42 would also fit.
                • KangamangusDriver
                  • Aug 2005
                  • 1870
                  You can pick up an M42 with 2/3 people
                  • rs4pro3
                    • 5808
                    I've put an m10 in the trunk of my 88 325is, and an m30 in the passenger floor board of the same car.
                    85 325e 2.7 ITB'd stroker
                    • Jon325i
                      • 6934
                      I think if you remove enough components from the engine it should fit. I've been able to haul a Getrag 260 in the trunk along with other gear without a prob....heck, you can even fit a couple of bodies back there if you're creative :-P
                      Jon
                      Rides...
                      1991 325i - sold :(
                      2004 2WD Frontier King Cab
                      RIP #17 Jules Bianchi
                      • Joe318is
                        • Sep 2005
                        • 6451
                        Ive transported and entire VW 8v engine and trans with intake and exhaust manifolds in the trunk of my old 84 318. The m42 should fit, a bit of work but i dont see why it wouldnt
                        Originally posted by vlad
                        • Dave
                          E30 RAT
                          • 11675
                          Jon
                          Sawzall will get you at least 4 or 5, I'd bet.
                          :jk:
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                          • e304me
                            • Feb 2006
                            • 1374
                            making a stroker are you?
                            • grapedrink
                              • 1514
                              Where in colorado?
                              I would put it inside the car. Just incase you get a flat or something happens you need to get to your spair tire. You got a 2-4 door? 4 door slide the passenger seat foward and stick in in the rear foot well. Might be able to do it in a 2 door also if you are strong.
                              Originally posted by DaveCN
                              Welcome.
                              Your car is a piece of shit.
                              Most of them here are, too.
