325i turbo project started. Good progress this weekend.
  • TCD
    • 438
    We pulled the complete exhaust, intake and valve cover and a few other things. Installed the manifold, wastegate, turbo and built the 3" downpipe and full exhaust. Intalled a powdercoated intake with 24lb injectors and valve cover. We have a few items to procur this week but hope to have it running by early next week.
    [img]http://groups.msn.com/_Secure/0PwDTAkYRKwVn5G4dybrZJto6XVUJQCULnBUL3wIUe3suWRY!K I4nvHQwVWJtkKFPr579oifc*SqirnEs1DRhmYR2997dA1ez/M20c.jpg?dc=4675459105512346478[/img]
    The exhaust has two O2 sensor bungs so we can run a wideband O2 sensor and use our data logger to record rpm, boost and a/f ratio while driving. No more tuning on the dyno for us.
    For updates next week.
    Thanks,
    Todd
    turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
    TCD
    1985 euro 535i
    503rwhp/485rwtq
  • e30Matt
    • 5077
    Looking good... be sure to polish the fins/BMW emblem on the valve cover :D That thing's gonna be a beast, I can tell.
    • diegom6
      • 4447
      Looking good Todd, I wish have that exhusat manifold for clearance porpousess, my system it's very tight.
      How well flow that maniolfd? Is not too much restricted or so??
      BTW...how many PSI are yuo gonna put there? what fuel magnament are you using?
      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
      • Jordan
        • 12916
        Looks good, keep us updated.
        https://mtechniqueabs.com/
        • TCD
          • 438
          Diego,
          A similar manifold on our M30s seems to flow just fine. I expect a minimum of 10psi non intercooled and 15psi intercooled using the stock engine management.
          How is your T04B compressor doing? Feel OK?
          Todd
          TCD
          1985 euro 535i
          503rwhp/485rwtq
          • diegom6
            • 4447
            Great!
            Well after putting my New compressor...I feld the car a bit more nervous at the same 6 PSI, but now I feel stronger and almost no pinging9 PSI, well soemtimes it give me a little noise of pinging. I have to fix it..
            Also I can hear a different noise from the filter...like when I'm engaged in second gear I feel like it were sucking air but it's closed the TB, also I hear soemtime like if it were another BOV type....like the Factory cars that have some kind of BOV...
            Also, you are using 24 LB/h vs my 21LB/h, what you are going to do in low RPMS? it will spray much fuel and wil be too much rich...I have a little problem with it...to correct adn feel less that over fuel mixture I have to turn up my boost at 9 PSI and gets better the response..
            Keep us posted! ;)
            • TCD
              • 438
              The Motronic ecu makes the necessary adjustments for all but WOT. I don't anticipate any problems with drivability. I don't think your SMPT thingy is helping you if you are having drivability problems. One of our requirements of a turbo kit is that it uses NO piggy back systems. Just a RRFPR and BTM for higher boost applications.
              Todd
              TCD
              1985 euro 535i
              503rwhp/485rwtq
              • diegom6
                • 4447
                my SMt6 is not working yet, cuz I didn't wired it yet...some cables are done.once is done I will let ya know how is working... :D
                • TCD
                  • 438
                  Are you sure it is rich? If so, try tightening the AFM spring. I also wonder about using the AFM as a blow through system. It is designed as a draw through. Maybe the flapper is getting maxed way early and going to open loop prior to WOT?
                  We position the AFM on the intake side of the system, bwtween the filter and compressor inlet.
                  Todd
                  TCD
                  1985 euro 535i
                  503rwhp/485rwtq
                  • diegom6
                    • 4447
                    Todd
                    yes, my A/R fuel meter show me rich when I push the gas pedal...I tighted the spring before, I wil do it again, justa bit more and see what happens
                    • TCD
                      • 438
                      Rich at cruise or rich at WOT. If it's rich at WOT then it the 12:1 Vortech that is causing the problem. You need an adj FMU like the BEGI unit. How else can you adjust the mixture?
                      Todd
                      TCD
                      1985 euro 535i
                      503rwhp/485rwtq
                      • diegom6
                        • 4447
                        Todd
                        at wot...it shows me rich..depends on crusie, If I hit a bit more than 0 PSI automatically the FMu raise and show rich, but works good. so sometimes I try to keep in vacumm instead of boost for fuel economy and such things.
                        I'm not sure how other way we can adjust the fuel delivery, for sure I will do it with my SMT 6 once I done. I can play with the Plus Width and such things.
                        Oh! BTW, I'm using 10:1 FMU not 12:1
                        • TCD
                          • 438
                          Diego,
                          You need to ditch the Vortech FMU.
                          Todd
                          TCD
                          1985 euro 535i
                          503rwhp/485rwtq
                          • be30
                            • Jan 2004
                            • 35
                            Turbo kit question?
                            Hi, Todd
                            I am interesting on your turbo kit M20.
                            I am new to turbo, and have no idea what to do.
                            So, here's some questions I have:
                            1. Do I need to change my ECU?
                            2. Is your kit bolt-on or I need some modification?
                            3. Do u know anyone around GA who can install kit 4 me.
                            Thanks a lot
                            • TCD
                              • 438
                              BE30,
                              Thanks for you interest. Answer to your questions:
                              1. No
                              2. Yes
                              3. Yes
                              Email me for more info and I'll add you to our email update list.
                              Thanks,
                              Todd
                              TCD
                              1985 euro 535i
                              503rwhp/485rwtq
