URGENT where does this go? Real oem doesnt help
  • torreira
    • Aug 2013
    • 260
    where do these tubes connect to?
    Thanks in advanced for the help!
  • redsubdivisions
    • Feb 2011
    • 1762
    looks like the heater hose recall BMW had on the E30's back in the day. It was to prevent overpressure and spraying hot coolant on people's legs.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • torreira
      • Aug 2013
      • 260
      but where does each hose go?
      • torreira
        • Aug 2013
        • 260
        im sure someone here knows, come on guys
        • QUKBMER
          • 8178
          Rear of the cylinder head
          • torreira
            • Aug 2013
            • 260
            are you sure? because the one on the back of the head goes to the lower tube coming from the heater core (aka return) i had bought that piece new from the dealer. Could it be that that valve gets spliced into the middle of that hose? It would make sense since that valve is is an over flow valve put there after a recall mentioned above. Maybe im wrong. can someone correct me?
            i dont want to go ahead and cut the new hose to find out i was wrong.
            • TobyB
              • 5296
              I threw those out. Too much junk back there already. Now I wear asbestos socks.
              t
              • Bmwb
                • Jan 2013
                • 196
                im dealing with those atm , broke the plastic tube smh , dont they just connect to the heater core 2 pipes sticking out from the cabin ,
                Sold Black BMW E30 325IS
                1987 bmw e30 euro part out
                1990 Bmw 325i Cabrio 2.9
                Metric Mechanic 2.9 stroker
                Holset Hx35w CXRacing Manifold
                MegaSquirt ARP HeadStuds
                OEM HG AEM Methanol injection
                20psi
                • Vtec?lol
                  • Dec 2009
                  • 3278
                  9 goes to the inlet of the heater core. the other end hooks up to the heat source.
                  • torreira
                    • Aug 2013
                    • 260
                    so does that mean #12 is spliced between the other hose that connects to the heater core inlet?
                    • torreira
                      • Aug 2013
                      • 260
                      figured it out thanks for the help
