For those who want to see something; S42.
  • Bavarian3
    • 1230
    2.0L built by BMW Motorsport for Italian Touring Cars. Raced over in the US by Randy Pobst. The car itself is a E36 320i. All BMW motronic; amazing.
  • YAN-3
    • Jan 2004
    • 6018
    oops
    • Ryan Stewart
      I Love Miatas
      • 8978
      Is this what they are running in the 2.0 class of the BTCC too or are those S14s?
      Im now E30less.
      • parkerbink
        • Jun 2004
        • 10138
        Nice, Thanks!
        • asubimmer
          • 6482
          dang I want his vc
          • Bavarian3
            • 1230
            Ryan,
            I believe in the BTCC early cars ran the S14 motor while the late models 96+ ran the S42 motors...
            • Pedro
              • 965
              Do you have any specs for that engine?
              http://www.volkswagenjettacup.com/
              • boom-monkey
                • 1104
                OMFG!
                Cool car though. Nice seeing you Mike.
                • Bavarian3
                  • 1230
                  The S42 came in different versions, here is some data on the 8/1995 evolution.
                  Bore / Stroke: 86,5mm / 85mm
                  Displacement: 1998ccm
                  Compression ratio:12.4
                  Rod length: 145mm
                  Intake cam degree / spread: 312 / 94
                  Exhaust cam degree / spread: 304 / 98
                  Intake valve diameter: 35mm
                  Exhaust valve diameter: 35mm
                  Intake dimensions: 52mm wide / 29.7mm height / 14.85mm radius
                  Slide throttle diameter: 46mm
                  Carbon airbox
                  Exhaust manifold: 4-2
                  Engine management: ecu4a.1
                  Performance: (DIN 70020)
                  285hp at 8300rpm
                  245nm at 7000rpm
                  max rpm: 8500rpm
                  Petrol quality: Super plus ROZ 98
                  Taken from S14.net ..
                  • Pedro
                    • 965
                    that was quick thanks.
                    • bmw332i
                      • 229
                      142hp/ltr ? Holy shit...
                      • Jand3rson
                        • 37587
                        So it's a 16V DOHC, correct? Not that I'm dismissing the coolness of the motor, and not knowing all the in-depth specs of both motors, but what's the difference between that an S14? I know that to create that kind of hp, an S14 would have to be built out to a 2.6 and this is a 2.0, but I'm still kind of confused. Is it more stable, or not as high strung?
                        • Avus E30
                          • 3650
                          its pretty hot is all I know
                          HDE30 <3
                          • BimmerToad
                            • Sep 2004
                            • 1537
                            S42 and M42 = 16v
                            S42 was based on the newer BMW engine architecture (M4X/M5X/M6X), where as the S14 was based on the older M10/M30 architecture.
                            2.0L S14s made as much power as the 2.0L S42 engines, but S42s were known for a more usable powerband, and a slight increase of torque ... comparatively, at a lower rpm, due to BTCC redline restrictions (8500rpm).
                            The engine is running motronic? Rumor has it the S42 induction system and engine management system WAS a BMW PN # to homologate over the parts to touring car racing.
                            San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                            • Steve30
                              • Sep 2005
                              • 261
                              I believe you're spot on with that remark. In-house BMW ems was used on this engine.
                              1988 M3
                              2005 330ci
