Looking for a thread - Glass Polishing
  • AndrewBird
    The Mad Scientist
    • 11898
    I'm looking for a thread and can't seem to find it. The OP made a DIY on polishing headlights using polishing disks from I think 3M. Can't seem to find the thread anywhere. Anyone know of it?
  • NardusDC
    • Jul 2013
    • 76
    I haven't seen that thread but follow Larry Kossila of Ammo NYC quite religiously. He had a //Drive episode for cleaning glass windshield. You may be able to adapt this to headlights.
    Check out the glass video here: https://www.youtube.com/watch?v=aVUtdlzrktI
    • AndrewBird
      The Mad Scientist
      • 11898
      That kind of polishing is only intended to clean the glass, not remove pits and scratches.
      Thanks though.
      • NardusDC
        • Jul 2013
        • 76
        Thanks though.
        Fair point. You may want to email him or message him through the AMMO Facebook page. I've asked him a ton of questions (including best way to spot clean my convertible top) and he's always been helpful and responsive. May be worth a try.
        Good luck!
        • Big Willy
          • 552
          Here's a quick guide from a volvo forum: Link
          instagram
          • 36brua
            • 689
            this is similar to one that I think was on R3v cant find it though same materrials
            My CA legal M60 swap
            The happening in our garage
            • AndrewBird
              The Mad Scientist
              • 11898
              While helpful, that was not the thread I was looking for. The one I'm looking for he used sanding discs, not a polishing compound.
              • catalyst.
                • Aug 2004
                • 131
                Start with say 600 or 800 grit wet sandpaper, work your way up to say 1500-2000, grab a buffing wheel (foam disc on a drill works in a pinch) use 3m perfect it, finesse it. It will look brand new.
                IF your doing this on plastic beware that you will not have any UV protection so the shinyness will only last +- 6 months and you will have to redo it.
                The only way you can 'scew up' is to start with to harsh a sandpaper then you wont be able to get the scratches out.
                94 325is
                • Dj Buttchug
                  • Jun 2010
                  • 7678
                  guy does amazing headlight restore on m5.
                  youre welcome
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Originally posted by Dj Buttchug
                    http://www.r3vlimited.com/board/showthread.php?t=307135
                    youre welcome
                    THAT'S IT!
                    Thanks.
