Timing belt squeal
  • Joev253
    • Sep 2013
    • 60
    Timing belt squeal
    Hey guys I recently swapped a m20b25 in my 325es it starts and runs but my timing belt squeals so I out a new OEM one in and it's still squealing.. I can't figure out why it would do this..
  • ak-
    • 12422
    Sure it's no the alternator belt?
    1991 325iS turbo
    • DEV0 E30
      • Oct 2004
      • 8904
      When you replaced the timing belt did you replace the timing belt tensioner?
      AutohausAZ sells two but I know people prefer SKF over URO.
      Also ^ double check this, and any of your accessory belts. I thought my timing belt might be making noise in the past but after tightening a barely loose alternator belt I haven't had any squealing.
      • dirtbag30
        • Apr 2013
        • 678
        that ^ but the problem is obviously not the belt, you have a seized or sticky pulley from a motor that has been sitting for how long before you swapped it in?
        i have no idea what i am doing with my life
        • jalopi
          • 2370
          Pull all accessory belts off then start your car up. If the noise is still present it's probably the tensioner pulley. If it's gone, add belts one at a time, then start up to find out which bearing is the culprit.
          • jeffnhiscars
            • Jun 2011
            • 6011
            Ill go out on a limb here and say that timing belts, having teeth, do not squeal.
            Alice the Time Capsule
            • Joev253
              • Sep 2013
              • 60
              It is the timing belt I took every belt off besides it and it still squealed. Also I had a new timing belt on it that wasn't OEM and squealed and was getting torn up. Got an OEM one and still the same things happening I'm positive it has to be some sort of pulley but idk what I put a brand new tensioner on too
              • Todd Black 88
                • Oct 2007
                • 3449
                It's rubbing on the timing cover?
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
