Will a front door fit inside?
  • UNCC Grad
    • Sep 2013
    • 47
    Looking to get a door from a guy to replace my dented passenger door. Can anyone confirm if a door will fit in the rear seat or trunk of a coupe? I'd rather not drive my truck since diesel is $4/gallon and it would be about a 2+ hour round trip. I measured and it appears it will be a tight fit if it does work.
  • NotColtonOrr
    • Jun 2011
    • 243
    I know a door will fit in a sedan. If it doesn't work just throw a blanket round it, stick it in the trunk as best you can and tie it down.
    • UNCC Grad
      • Sep 2013
      • 47
      That may have to do. The tunnel in the floorboard makes it questionable to fit in the backseat
      • BobombETA
        • Apr 2008
        • 1575
        Can confirm, am door.
        But seriously, yes I've done it in a coupe. It will fit in the rear seat. I took out the passenger seat (4 quick bolts) but it might not have even been necessary.
        Instagram
        Current: 99 M3
        Past: 84 325e, 84 528e
        • naplesE30
          • Nov 2007
          • 1841
          Yes I picked up a coupe door in my 318is back in the day.
          • LivingLegend06
            • Dec 2006
            • 1604
            I tried for some time to get a coupe door in the back of a coupe and was unsuccessful. It will fit in the back of a sedan pretty easily though.
            • ParsedOut
              • Sep 2005
              • 1437
              Remove dented door, drive, pick up door, bolt door on, drive home?
              • kway
                • 1084
                I tried unsuccessfully to fit a passenger side coupe door in the back of a coupe. I was able to fit it on the floor though with the passenger seat removed and the upper rear corner of the door sticking out the window.
                '84 318i - Lapisblau/Schwarz (in cryosleep)
                '06 330i - Titansilber/Schwarz
                • mr2peak
                  • 2388
                  Will a hood fit?
                  How about a one-piece driveshaft?
                  Is there any part of an E30 that won't fit inside?
                  Drive it hard. Maintain it well.
                  A Topless Memorandum
                  • TobyB
                    • 5298
                    Complete engine and trans in trunk- check.
                    t
                    • FLG
                      • Sep 2011
                      • 3165
                      This. That's what I'd do.
                      But seriously, just remove the passenger seat.
                      Sent from my SCH-I545 using Tapatalk 2
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
