Keys to Success!
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Originally posted by FLG
    Op i have a spare trunk lid. Gonna see how or if the lock can be removed from the outside
    Sent from my SCH-I545 using Tapatalk 2
    Lol wait was that actually a logical idea?!?!
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • Andy.B
      • Sep 2011
      • 1650
      Cut hole in trunk lid and buy a new one and paint it to match lol it's the only way... Jk don't listen to me.
      Pop off the roundel and hole saw through the trunk, open trunk, and stick the roundel back on. No one will ever know.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Until it rains and water goes into the cuts under the roundel and makes his trunk floor rust out like mine... If he cuts the trunk lid at all its gotta be replaced. He could get the door lock out at the cost of a new window and probably some cut fingers.
        • mitchlikesbikes
          • Dec 2013
          • 858
          your best bet is going to be rolling the window up somehow.
          IG: @mitchlikesbikes
          • Andy.B
            • Sep 2011
            • 1650
            I wasn't serious. Lol.
            I already posted a solution: remove the power window switch, jump power and ground to the harness to wind up the window, and remove the door lock tumbler.
            Or, tap into the harness and trigger the solenoids to unlock.
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              lol I was hoping so. Your idea is probably the best way with out breaking anything. Manual windows FTW
              • Andy.B
                • Sep 2011
                • 1650
                What year did they do away with the ability to manually wind the windows up manually? I thought you could pop off the plastic cover on the door card and use an allen wrench?
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  I think the same years as the face lift.
                  • FLG
                    • Sep 2011
                    • 3165
                    Have you guys ever tried to remove a door panel with the door closed? It's nearly impossible without ruining it.
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      would you have to for taking the window switch out?
                      • TSI
                        • Mar 2012
                        • 691
                        In my experience, all of them have this ability. My 88 and a friend's 91 have the caps. You need to puncture the vapor barrier, but a wrench will definitely wind the window up.
                        • Andy.B
                          • Sep 2011
                          • 1650
                          But a door card is much easier/cheaper to replace than a trunk lid.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            true unless he got an identical color from a scrap yard or forum member on the cheep.
                            • FLG
                              • Sep 2011
                              • 3165
                              I'm not saying make a hole anywhere but I'm sure there's a way to get this done.
                              Op try pulling up the door lock a bit, while holding it try to open the door. My car, even double locked, there would be enough play in the passenger side lock to still get the door open.
                              Will be home soon to check on that trunk lid lock idea.
                              • mitchlikesbikes
                                • Dec 2013
                                • 858
                                why would the door have to be closed for removal? if the window is rolled down enough to block the lock cylinder then you can just reach in and unlock the door.
