what torque wrnch should i buy?
  • MoparJ
    • May 2007
    • 258
    Originally posted by FLG
    Got a snap on digital that i love. Does angle as well, which is great for head bolts. Its not cheap but i figured i might as well have one good torque wrench laying around.
    I borrowed my friend's Snap-on Techangle when I did the head gasket on my e36.......that is easily the most bad-ass wrench I've ever used.
    Jason
    • e30vert
      • Jan 2005
      • 1789
      Also , always leave the torque wrench dialed down to zero pounds of torque when not in use so that they have a better chance of staying within calibration.
        • 34827
        AFAIK not zero. You want it low, but not too low. I usually set mine at 20-30.
        • marshallnoise
          • Sep 2013
          • 3148
          Mine says lowest setting. I think that is the main point.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • Vivek
            attention whore/retard/bitch
            • 6167
            Originally posted by nando
            the HF wrenches are fine for home use. they should be recalibrated every once in a while, but at $20 you may as well just get a new one. Mine is due for replacement, I've had it for 10 years with no issues though.
            no need for a $500 snap on to use in your home garage, unless you have cash to burn.. I buy expensive tools when I know they will make me money, not to have them sit in my tool box to be used once or twice a year. :p
            I bought a craftsman one after snapping an oil filter housing bolt with my HF one
            1992 Mauritiusblau Vert
            2011 Alpinweiss 335is coupe
            2002 540i/6 Black/Black
            2003 GSX-R 750 (RIP)
              • 34827
              craftsman quality sucks. it's also overpriced.
              I'm not really sure why you were using a torque wrench on the OF housing anyway? it's a hollow bolt, it wouldn't be hard to break..
              • Vivek
                • 6167
                What would you recommend above HF quality that's not overpriced, or super expensive like snap on? It was a bolt securing it to the block, not the top bolt that holds the cover on.
                  • 34827
                  sorry I assumed M20
                  M10 bolts don't take much torque. I wouldn't expect the 1/2" wrench to be very accurate at lower values (no matter what brand it is). it would still be pretty easy to break one.
                  • TimbyMaTombo
                    • Jul 2012
                    • 413
                    I got an Ace Hardware torque wrench. Cost $50 and has a lifetime warranty. It's easy to adjust and the click is both very audible and tactile so I would recommend it.
                    • dnguyen1963
                      • Nov 2011
                      • 2648
                      I bought HF wrench for $9.99. It does not feel like the high end wrench, but works just fine. Like Nando said, it's something I use only a few times a year. Invest in a good one if you work on your car weekly.
