What To Swap In Place of an M10 With Blow - By
  • KI4UJO
    • Jun 2011
    • 642
    So, while swapping a throttle body, I noticed a nice coating of oil on top of the TB. It is also in the intake. Basically, I have blow-by. So, what do I do here? I could rebuild the M10, which would bolt right back in with no issues, but then I still have an M10 (which isn't something that I have a problem with, but more power would be nice).
    Option 1 - Rebuild M10
    Option 2 - 24v swap
    Option 3 - M30 Swap
    I have read about these various swaps, but none seem to address M10 cars. Everything I have seen assumes that I have an M20. So, what does r3v recommend? Basically, I want something that is reliable and can be my DD (since the e30 serves that function now).
    IMG_0145 by Jonathan Martin, on Flickr
  • jaywood
    • Jul 2010
    • 4528
    LSx
    • einhander
      • Apr 2004
      • 2024
      Turbo M10.
      But seriously, rebuild M10. Swapping in an old engine just delays the inevitable rebuild.
      Might as well keep things simple.
      2011 1M Alpine white/black
      1996 Civic white/black
      1988 M3 lachs/black
      • roguetoaster
        Biggus Tippus
        • 7830
        Since it's a DD get an M42, it's the only no fabrication option that can easily be done in a weekend, and will bolt to your current transmission. Or buy another M10...
        ---Will NOT bolt to your current transmission.
        • JinormusJ
          • 6887
          I second turbo rebuilt m10. They hold nicely to boost and they're super light; swapped over to FI system of course
          • blunttech
            • 12850
            Ive never had a motor that didnt have some degree of blowby the way i drive them. If you just noticed it now after pulling the TB maybe just continue driving it as is. Unless youre itching to do something which i totally get
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • mrcheezle19
              • Apr 2012
              • 1451
              el es.
              Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Id throw in a m42 or another m10 for the sake of being cheap and the easiest to do.
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • ak-
                  • 12422
                  remove your crank case hose, plug the hole it goes into, and see if actual smoke is coming out of your valve cover to gauge how bad you're blow-by is. Like Blunt said, a little is normal.
                  or do a leakdown test
                  1991 325iS turbo
                  • KI4UJO
                    • Jun 2011
                    • 642
                    When I remove the oil cap right after shutting the engine off, I do get smoke out of the crankcase.
                    As for the turbo M10, I don't see that happening. Here in TN, this thing actually has to pass an emissions test. It is performed on emissions only, no visual. What is honestly turning me off to the M10 is the lack of e30-specific M10 parts and knowledge. For example, the r3v solution to any M10 idle problem is "delete the ICV". That's great, if it's 90 degrees everyday. However, when it's 20, I have to stay with it for a few minutes to warm it up.
                    Also, I wouldn't mind having more power. A turbo setup is just more money/time than I'm willing to commit.
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      So put a cat on it. Tons of cali guys have turbos and we have to deal with bullshit visual inspections.
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • ak-
                        • 12422
                        Take the cap off while it is running, and see if considerable smoke comes out.
                        1991 325iS turbo
                        • Hooffenstein HD
                          • Nov 2012
                          • 1388
                          That is not true at all.
                          • TurboJake
                            • 3780
                            I want something that is reliable and can be my DD.
                            M50B25 Non-Vanos, M20, or M30 for ultimate reliability.
                            M30 if gas mileage less important, Uber torque.
                            M20 for uber reliable, slightly better gas mileage
                            M50 for reliable, but better mileage. Engine doesn't sound nearly as good as the other two.
                            Oil film in the intake is normal. Even happens with modern engines.
                            Leave Me Transaction Feedback
                            • einhander
                              • Apr 2004
                              • 2024
                              Any of those engines, unless rebuilt, is going to run into a required rebuild in the future. Plus, with the added time and money of swapping them in he's better off rebuilding the engine as it can be done much cheaper and doesn't require any extra effort.
                              If it weren't a daily, I'd say swap, but it seems like the PO can't afford the time to have the car out of commission while he shoehorns a new engine in.
                              1988 M3 lachs/black
