What To Swap In Place of an M10 With Blow - By
  • roguetoaster
    Biggus Tippus
    • 7830
    Originally posted by Hooffenstein HD
    That is not true at all.
    In what way? We just put our old M42 in a presiously M10 powered car, no fabrication was required, and it took less than two hours of easy work. Clearly you need to change the engine harness and motronic unit.
    Perhaps there are other drop in swaps, but they require work beyond the engine bay.
    • jakeb
      • 1909
      Perhaps there are other drop in swaps, but they require work beyond the engine bay, and an M42 let's you reuse or have a spare transmission.
      The m10 trans will NOT bolt up to the m42.
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • roguetoaster
        Biggus Tippus
        • 7830
        Right you are, I was making assumptions, actually looking at the two transmissions makes it quite clear.
        • 2mAn
          Señior Mod
          • 21085
          M12/7
          Race cars for sale and race cars wanted, rally cars, spares, memorabilia, transporters and pit equipment for sale with on-line photos and spec sheets.
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • DER E30
            • Sep 2013
            • 2349
            Originally posted by jaywood
            LSx
            Motion 2nded
            -Christian
            • lukeADE335i
              • Apr 2013
              • 1389
              If you just did the swap, why were assumptions needed? Swapping in an M42 in 2 hours? A weekend would be doable if you knew what you were doing, but it isn't any more a straight drop in swap than an M20, M30 or M50 is - you need the engine, mounts, gearbox, wiring, cooling system & prop shaft for any of these swaps (although you could use the M10 gearbox behind the M30 with an uprated clutch). You also need to fabricate a bracket for the coil pack.
              As to the OP - M10s can run for a long time with some blow by. As it's a daily, if it's still running ok & passing your emissions inspections I'd just leave it be.
              My e30: OEM+ with M30B35
              • roguetoaster
                Biggus Tippus
                • 7830
                We were moving an M42 from a crashed track car to a new car. If you've taken an M42+transmission out and replaced it as many times as we have it takes very little time, and most could do it in a weekend. Clearly, you need all ancillaries for any swap, but couldn't you reuse the M10 driveshaft with any swap, or it is markedly different? The coil bracket was cut off of the old car, the only other change we had to make was the lower mount for the radiator. An M20, probably isn't much harder, an M30 requires a few non stock parts, and a bump in the firewall. With both of those you would probably want to change the rear diff too, not only because of the ratio, but to ensure longevity.
                It is still my opinion that an M42 would be the most appropriate non-M10 engine. Clearly another M10 would be fine.
                The new car only had an M10 fitment transmission, which was in the trunk. I just assumed that the G240s would be the same. I apologize to the OP for that error.
                • lukeADE335i
                  • Apr 2013
                  • 1389
                  Fair enough... The G240 M10 driveshaft is different from the M42 driveshaft (despite both boxes being 240s they are actually quite different - different bell housing, different ratios in the box, different output flanges).
                  • KI4UJO
                    • Jun 2011
                    • 642
                    A few things to address - First, I'm still in HS and will have time over the summer to swap the car. Myself, after reading extensively about each swap, I am considering going 24v. Fuel mileage is on par with what I would like, along with the great increase in power compared to the M10. Is this a bad idea? Also, I'm not concerned about the added weight. Am I making a good decision?
                    As for the M10, I did a compression test today. The results were between 105-115, so something is definitely worn.
                    IMG_0145 by Jonathan Martin, on Flickr
                    • E30_Pare
                      • 7801
                      honestly cheapest and easiest thing to do I swap in another m10. They could be had for 200$ with a trans, probably running. Then if you break anything on that motor u still have a spare m10 for parts. Wait till you have the means to do a proper swap.
                      DREWLIENTE
                      1$ PShops PM me
                      • LJ851
                        • 7919
                        How much money do you have to spend?
                        Lorin
                        The M30 is God's engine.
                        • Nick_S
                          • Apr 2011
                          • 3658
                          I vote M42. They're fun little engines and will feel pretty stout compared to an M10. You can find them cheap. Hell I just scrapped mine after pulling all the usable goods off since I couldn't find anyone to buy it.
                          Or you could go M50 for another fairly basic swap. Find a wrecked E36 325, pull the engine, trans, DS and dif out. Replace some gaskets, get an oil pan and engine mounts and do some wiring and you'll be set. I did my M50 for around $1500.
                          91 318is M50 swapped
                          05 Honda Pilot
                          24V swap thread
                          • KI4UJO
                            • Jun 2011
                            • 642
                            Well, I think I answered my own question. I bought this
                            • DER E30
                              • Sep 2013
                              • 2349
                              Kool... That sure got whacked hard!
                              -Christian
                              • Rennsport
                                • 2139
                                Judging by those tail lights, either they didn't work, or weren't bright enough to be effective....
                                m106 1990 e30
                                e36 daily
                                e32 cruiser
