whats better for an LS1 ?
  • helalo
    • Oct 2012
    • 93
    if i was gonna put an LS1 engine in an E30, would it be wiser to find a cheaper clean 318is than a 325is ?
    can the suspension and brakes on the E30 deal with the LS1 or they MUST be replaced ? what else would need to be replaced ?
  • yahh
    • Aug 2012
    • 800
    Use an e36 shell, it will save you more money in the long run.
    s50 86 325e Project
    S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
    Feedback Thread
    • TurboJake
      • 3780
      Leave Me Transaction Feedback
      • ST1G
        • Oct 2012
        • 6690
        • Chinampa
          • Jul 2013
          • 247
          - 90 325is
          • 10Toes
            Me Father Was A Tree
            • Jan 2008
            • 61222
            Get a Corvette, it will save you more money in the long run.
            • jaywood
              • Jul 2010
              • 4528
              E30 LSx > all.
              If that was easily CA smoggable I'd already have one.
              • cferb
                • 1442
                A 325 will be easier to come across, the 318 is sought after for it's own reasons so really just keep an eye out for both. If you really wanna save money a 325e or early 318 is your best bet if you don't mind diving boards.
                The rest I can't help you with, don't know anything about the swap
                • Wh33lhop
                  • 11705
                  You can't help him with this advice, either. If you HAVE to swap into a BMW, do an E36. If you HAVE to swap it into an E30, no the suspension and brakes are not good for 350+whp and neither is the small case diff in a 318; furthermore the smaller struts and drum brakes of the really early cars will only be worse.
                  But, as was said before, an e30 will have a harder time putting that power down than an e36, let alone properly controlling it.
                  paint sucks
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    Never would I have expected r3vlimited to encourage a e36 lsx swap...
                    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                    Originally posted by scabzzzz
                    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                    1989 325i - Project/weekend driver
                    2002 325i - DD
                    2005 Suzuki SV650 - Toy
                    • R3Z3N
                      • Jan 2011
                      • 3056
                      If one does an E36, only use an M3. The vanilla variants are already booring enough.
                      • cferb
                        • 1442
                        Good point about the early struts, but doesn't that only apply to early 318s and not 325s? A diff swap for a 318 is hardly a concern with a project this size.
                        Either way, OP check out the v8 swap section, you'll get a better response.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          E36 shell will be the cheapest and easiest.
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • helalo
                            • Oct 2012
                            • 93
                            theres a 323is E36 that needs an engine, it has new tires and cooling system overhaul. 8/10 in and out. guy wanteds 900$ for it. i can use that i guess.
                            but i have a thing for an E30 :( i guess ill see if i can find cheaper shells 325`s
                            • cferb
                              • 1442
                              Just do an e30, obviously it can be done, it's been done plenty of times, just be sure you know what you're getting into. If you start right off the bat with a shell you're not happy with, what hope do you have of ever being satisfied with the car? On top of that, if you don't like the shell you're swapping into then what's the point of swapping at all?
                              Do a lot of research before you make any purchases
