Need help/ Enthusiast Input
  • ginonj
    • Mar 2014
    • 16
    Car is a completely stock 1988 BMW 325is with m20 6cyl.
    Last night while driving, I managed to to pinch and create a hole in one of my upper radiator hoses, due to the engine mounts I'm assuming, through driving and the fan making contact with the rad hose. I noticed smoke and and popped the hood to then getting sprayed by coolant and finding the problem. I managed to safely drive the car home seeing I was a short distance away, and I also did not experience any troubles with over heating and the car drove extremely well. Also while this happened, the MPG gauge on the cluster stopped working about the same time everything happened. My questions now are how should I go about fixing the MPG gauge? Check fuses etc? And is there a specific coolant I should use on these engines to prevent troubles/ failures, or is any coolant okay? and should I replace all coolant hoses with silicone hoses, or get OEM replacements. Does the hose that is crimped, have a part number? Thank you in advance for your time and effort!
  • keine30
    • Oct 2013
    • 50
    i can tell you for sure that you want to get BMW coolant and distilled water (it doesn't come 50/50 mixed) to refill with. anything else isn't up to BMW spec, and i'm told the stuff from the dealership isn't that expensive anyways.
    If you were arrested for being a good mechanic, would there be enough evidence to convict you?
    "The cycle you're working on is a cycle called 'yourself.'" -- Zen and the Art of Motorcycle Maintenance
    • tytypetersen
      • Mar 2012
      • 347
      The blue bmw coolant from the stealership is like 25 bucks for a jug.
      • blunttech
        • 12850
        just get regular hoses. But look for the reason your hoses are contacting your fan. check motor mounts . tolerances are tight in there but the motor may be moving around. email me and I can send you a list of hose part numbers you need
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • McGyver
          • 4637
          Assuming its the top hose, you probably need that dumb clip (or a zip tie) to hold the hose back against the engine. It happened to me once and i just drove it with ductape on the hose until the new hose came. get a hose from blunt.
          as far as coolant? unless you have BMW stuff sitting around, just get the green stuff. Remember to use DISTILLED water if you don't get the 50/50 mixed coolant. M20s don't need anything special if you're changing your coolant 1-2 times a year like you should.
          • ginonj
            • Mar 2014
            • 16
            Thank you to everyone for your help. I now just need a clue about the MPG gauge issue? Is it related? Like I said it is stuck past 40 (the needle won't move from the left side) and no longer works.
            • 101
              • Jul 2011
              • 764
              I don't think the problem with the econometer is related to your coolant hose failure, but it MIGHT be. The econometer uses engine vacuum as one of its inputs. If there's a vacuum line that also got tangled up and torn at the same time, that could be it.
              If not, welcome to the world of the fickle E30 cluster!
              I have an econometer that will occasionally stop working - but a well placed love tap on the top of the dash gets it back in order.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
