Removing Air Box air horn, any gains?
  • E30/M30
    • 224
    Originally posted by Spaz
    Originally posted by E30/M30
    Leave the air horn in. I had mine out for a while, and when I put it back in, I felt a smoother idle and stronger mid-range pull.
    If you didn't replace it with some thing then it whould have been sucking hot air from the engine bay ? So may be this caused it to run less well than before ?
    Unless i'm misunderstanding you ?
    Cheer's
    Andrew
    sorry andrew but you are misunderstanding us,
    the air horn is a piece of plastic pipe in side of the top half of the airbox, it connects to the afm with four bolts.
    if you take off the top of the air box you'll see it and that will clarify everything up for you.
    Thank's for clarifying that Spaz :)
    Cheer's
    Andrew
    • Spaz
      Crazy Canuck
      • 2276
      Cheer's
      Andrew
      Cheer's
      Andrew
      no problem.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • DaN
        • 1265
        Yes they are swappable, in fact I'll get my friend to dyno his car with both and see which makes more power. :)
        Great, thanks alot man.
        Could you get pics of both air horns?
        The one in my airbox just snaps into place, will the m3 one do the same ?
        • Stu Mc
          • 4083
          I can't believe there is a thread this long about the airbox horn. ;)
          • rwh11385
            lance_entities
            • 18403
            It's all about the free HP mods. If only they knew that turning your fan on position #2 boosts your top-end HP. ;)
            • DaN
              • 1265
              Originally posted by Jonathan 90 M3
              Originally posted by DaN
              Is it possible to swap in the m3 air horn, onto a 325is airbox? lol
              I'd cut mine, but then I would loose the outward flare at the end.
              I suppose it would be a waste of time, but I have time to waste, haha.
              Any Update on this?
              • Rob
                • 8166
                or dyno figures?
                *tongue in cheek*
                BEERTECH
                  • 34847
                  who wants to spend $50-$100 to find out that the stupid air horn gives a gain of .5hp?
                  • DaN
                    • 1265
                    Well some people have free access to a dyno, or they are planning on dynoing anyway.
                    If they have the parts, it shouldn't be too much trouble.
                    • Jonathan M3
                      • 1837
                      My dynos are free :P , we'll most likely dyno it this friday.
                      I'll do new baselines on the 325is with the m20 horn, then with the s14 horn, then no horn. Let me know if theres anything else you would like to try.
                      '05 E46 M3 Imolarot/Cinnamon - CURRENT
                      '98 E36 M3 Estorilblau/Dove - SOLD
                      '90 E30 M3 Brilliantrot/Black - SOLD
                      SRS BSNS Motorsports - 24hrs of LeMons Racer
                      • Nate325ic
                        • 462
                        I just took of the horn and then cut the front lower part of the airbox off below the filter, figured it would let more air in...that and I'm a cheap bastard
                        gives it a nice growl that I like aswell
                        • Rob
                          • 8166
                          my prediction: wont be much difference on the dyno
                          BEERTECH
                          • Jonathan M3
                            • 1837
                            I agree, I'm just doing it out of pure curiosity. ;)
                            • DaN
                              • 1265
                              Cool,
                              It could be the great e30 Air intake mod shoot out!!
                              Here are the setups:
                              cone air filter
                              airbox and stock filter, 1)stock horn, 2) s14 horn,3) no horn
                              airbox and a k&n,1) stock horn 2) s14 horn 3) no horn
                              airbox no filter 1) stock horn 2) s14 horn 3) no horn
                              no airbox, no filter
                              Got it all? :shock:
                              It's only 11 runs, lol
                              • randomtask37
                                • 3154
                                Cool,
                                How about a run with a cone air filter, a run with the airbox and stock filter, then one with the airbox and a k&n. And depending on how much gas you have, try each air horn with the different airbox filters. And no horn for all of them.
                                Oh, and one with no air box, no filter. One with airbox, stock horn, no filter, and one with airbox s14 horn and no filter.
                                Got it all? :shock:
                                lol
                                :rofl: yea got it!!!
                                98 M3/4/5
