Running on fumes....actually works!
  • Mr. Burns
    • Aug 2011
    • 3516
    Interesting.
    Would this not mess the air/fuel mixture and cause the engine to run lean?
    Regardless...
    Pretty interesting/hillbilly innovative
    Log into Facebook to start sharing and connecting with your friends, family, and people you know.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • bastianshaw
    • Jan 2007
    • 2210
    thats pretty cool
    • kickinindian
      • 2327
      any more info on this? i would love to do this with my dads toyota just for the fuck of it
      • russc
        • Jun 2013
        • 56
        200 miles a gallon running their cars on vapors.
        Bullshit.
        This kind of stuff is usually accompanied by a conspiracy theory about the big oil companies.
        • monticello
          • Sep 2007
          • 202
          I don't believe it either. The engine stalled because he starved it for air, not fuel.
          • Mr. Burns
            • Aug 2011
            • 3516
            It's a super easy mod...someone else needs to try this.
            But I don't buy the 200mpg tho...that's rich.
            • keine30
              • Oct 2013
              • 50
              how he did this:
              shitty truck had a short to fuel pump so the guy hard wired a switch to it, bypassing the fuse/relay box.
              starts truck, runs like any normal vehicle does.
              when he puts his hands over the tubes, buddy shuts off switch that sends power to the fuel pump. motor starves and dies.
              we need more scientific literacy in this forum.
              If you were arrested for being a good mechanic, would there be enough evidence to convict you?
              "The cycle you're working on is a cycle called 'yourself.'" -- Zen and the Art of Motorcycle Maintenance
              • kickinindian
                • 2327
                well their is this guy...
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  more theories.
                  Originally posted by keine30
                  how he did this:
                  Kickindian posted what seems to be the closest to a legit sit citing real world results, and actual investment companies (but dropping it due to no patent...duh)
                  could this be yet another "who killed the electric car" theory?
                  could you just imagine if this was cleaned up, and engineered into something that would be mass produced for the everyday man?
                  it would literally change the world.
                  • 15Michaeljoseph
                    • Aug 2013
                    • 1693
                    There's no way this can be that good, otherwise he would be a billionare now, and be sitting in a nice big office at GM...or whatever company he chooses to sell his design to first.
                    Secondly, I'm sure some scientist came up with something similar sometime before and the idea was scrapped. No way a guy who used a LIGHTER to look into a GAS TANK was the first one to come up with this.
                    I'm skeptical.
                    --Mike
                    (OO=[][]=OO) For Life
                    • nrubenstein
                      • 3148
                      LOL.
                      If this shit actually worked, someone would be marketing it right now in an actual product and not as vaporware. You will note that no one gets these things running on a proper test rig (i.e. under controlled conditions).
                      2002 BMW M3 Alpinweiß/Black
                      1999 323i GTS2 Alpinweiß
                      1995 M3 Dakargelb/Black
                      - S50B32/S6S420G/3.91
                      1990 325is Brilliantrot/Tan
                      1989 M3 Alpinweiß/Black
                      • dewme5
                        • Mar 2014
                        • 165
                        14.7:1 = stoich mixture = 'nuff said
                        • nrubenstein
                          • 3148
                          The one example where anyone showed real engineers testing it, they should mild increases in fuel economy in exchange for massive increases in emissions. Classic lean burn side effects.
                          • econti
                            • May 2014
                            • 1152
                            Not to mention that if you run it too lean you run the risk of melting things
                            • keine30
                              • Oct 2013
                              • 50
                              the fact of the matter is that because of basic chemical laws, you simply can't run a motor on significantly less fuel than it uses stock. it literally cannot happen.
                              plus there's no way to control the fuel flow and raise the RPM. sure, as you open the throttle the engine will pull more air in the intake, and theoretically more 'vapor,' but not in a controlled amount.
                              videos like this rely on the fact that most people, unless they have a vested interest in mechanics and cars, just see that lump of metal under the hood as magic. sure, they know that the gas goes in and it gets ignited by the spark plugs and the used gas goes out, but the average person don't know exactly WHY that happens, or the extremely exact parameters that need to be fulfilled for that to happen effectively.
                              not to mention that the injectors/carb already 'vaporizes' the full upon injection... gasoline isn't flammable, gasoline fumes are. c'mon guys.
