Garage padding materials?
  • Aleksey
    • Feb 2011
    • 336
    I'm restoring my car and want to put something on garage walls to protect the paint if I ever brush against it.
    The only thing I could find are 'plumber' pipe wraps (insulation) to wrap some of the corners around in.
    Anything other than winter blankets on the wall?
    Founder @ Maintenr. Take control of your vehicle maintenance.
  • dnguyen1963
    • Nov 2011
    • 2648
    The pink foundation insulation foam panels work well, except for the color.
    • glnr13
      • 1334
      Pool noodles work well
      • Sps
        • Apr 2013
        • 265
        Dnguyen1963 is on to something. Home dumpo sells large sheets of styrofoam that you can attach to the walls with either velcro or spray adhesive. They sell them in thin or thick panels.
        ATTENTION:
        FOR THOSE WHO HAVE NOT DONE SO, PLEASE DO SO AT THIS TIME
        • Aleksey
          • Feb 2011
          • 336
          Thanks guys.
          What spray adhesive would I use to attach something like this to a brick wall?
          • Sps
            • Apr 2013
            • 265
            Originally posted by Aleksey
            Thanks guys.
            Get the 3M spray adhesive. For brick, just load the spray up pretty good on each corner. Just make sure the adhesive that you purchase is good for Styrofoam. Some sprays will have chemicals that will melt Styrofoam.
            The other option would be to anchor hooks at the top corners and hang the sheets. That way you can remove it easier when it get too beat up.
            ATTENTION:
            • hammrdwn510
              • Mar 2014
              • 133
              Liquid nails (check that its safe to use with styrofoam as mentioned above)
              + caulk gun
              • AndrewBird
                The Mad Scientist
                • 11898
                FYI, attaching rigid insulation to a wall is a code violation. Fire safety hazard as that stuff burns quick.
                Why dot just get door bumper guards meant for this?
                • Aleksey
                  • Feb 2011
                  • 336
                  Where do I buy this? Let me guess that strip is $150?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Lots here for cheap:
                    • Aleksey
                      • Feb 2011
                      • 336
                      Thanks!
                      • Thizzelle
                        • 4422
                        I have a old e30 door trim on my wall. Just posistion it to right hieght. Looks cool too
                        "I wanna see da boat movie"
                        "I got a tree on my house"
