Starting s52 after one year sitting
  • VitalkaE30
    • Aug 2012
    • 238
    Hey guys, I need some advice. I'm picking up my e30 from the body shop where it sat for a year and is almost ready. The car has full turbo S52 swap. I plan on changing oil, coolant, fuel filter, diff and tranny fluids once I get it home. Is it safe driving it the way it is for about 50 miles to get it home? I know the battery is dead and won't hold charge so will get a new one.
  • Old city bimmer
    • Jun 2014
    • 1114
    crank it without spark for a few revs to get oil up the passages then fire her up. should be fine since it has synthetic oil in it.
    323i MTEC1
    Z3 coupe
    E60 M5
    • AndrewBird
      The Mad Scientist
      • 11898
      Might want to drain the old gas out and put fresh in. If the tank is low, adding a few gallons of fresh would likely be enough.
      • VitalkaE30
        • Aug 2012
        • 238
        Should I pull the fuel pump fuse as well?
        The tank is at around 3/4 IIRC
        • TurboJake
          • 3780
          Just get the oil circulating before firing it up... It's not a glass engine that'll kill itself at the first chance.
          Wait, S52.... Might as well just replace the whole thing.
          (Seriously though... Just get the oil circulating.)
          Leave Me Transaction Feedback
          • Old city bimmer
            • Jun 2014
            • 1114
            No need to pull the fuel pump fuse unless it gives you piece of mind.
            323i MTEC1
            Z3 coupe
            E60 M5
            • UNHCLL
              • 8790
              If you didn't put stabilizer in the tank, chances are it has separated and you have bad fuel in the tank now.
              Since E30's have a fuel tank drain, and you have a turbo motor, I'd drain the gas and fill with fresh.
              Below the radar...
              • adjmcloon
                • Apr 2012
                • 446
                +1 on that. You'd be surprised what gas varnish will do to keep it from running right. ;)
                • VitalkaE30
                  • Aug 2012
                  • 238
                  Thanks for the suggestions guys. I'll drain the gas and disable spark before cranking.
