Engine Swap - How Difficult?
  • Black325e
    • Jun 2014
    • 136
    Wasn't sure where to put this thread because I am not regarding a specific engine swap or anything. My question is, how hard is it? Yes I know the general process of putting an engine in but then again, it's harder than it seems haha.
    I am asking because my girlfriend and I found a perfect shell for $500. It has full interior, all electrical, steering, brakes, tires, rims, all that. Oh and the shell has crappy spray paint under a full metal body that could be repainted. No dents whatsoever and zero rust. I say that is one HELL of a deal, if you ask me, so we are thinking about it. We are either coming or not coming home with a shell tomorrow so we need a lot of comments! Is it worth it?
    Here are a couple questions we have about the process. Would it be worth it to take it to a shop to drop an engine, or would it be better to do it ourselves? Could two people with light knowledge on cars be able to buy an engine and drop it in by watching videos and getting advice? Let us know if it's good to do. We want to know - she is fishy about it but damn, I want to help rebuild an E30 haha.
  • Liquidity
    • May 2014
    • 395
    This is most certainly an "if you have to ask" question.
    • glnr13
      • 1334
      it's a tough learning curve.
      things you need:
      garage/driveway where the car will be immobile for a while
      engine stand
      engine hoist
      bentley manual
      lots of tools
      patience
      ingenuity
      you should do as many of the "while you're in there" things.
      new gaskets, cooling system, valve adjustment, timing chain/belt...
      the list can go as long as the depth of your pockets.
      do it, you'll never look at an engine the same again.
      • kingston
        • Jun 2010
        • 2669
        @ people with knowledge of cars could certainly do it, especially if it was the engine originally intended for the car. If the engine harness is in, and it really just needs a motor, that's not really that difficult at all, assuming you know which end of a wrench to hold. Good luck!!
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • Silverdogz
          • Aug 2012
          • 168
          I'd say go for it, especially if the gf is willing to help out. Though I would recommend the M20B25 if this is your first time doing this.
          Sent from my Lumia 928 using Tapatalk
          so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Well what motor do you want in it? throwing a m20 in it wont be extremely hard cause its the original motor. However your going to need lots of tools, A hoist, a stand so you can prep the motor to be dropped, jack stands for the car to sit on , bentley manual of course and lots of time and money. Even doing a m20 wont be easy
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • dewme5
              • Mar 2014
              • 165
              Make friends locally with someone who's done a swap before. It's not hard to do, but tools intensive.
              • TobyB
                • 5254
                If you're taking an engine out of one car and installing it into another,
                it's pretty easy. Honestly, things like taking the hood off and reseating the
                engine onto the transmission are the hardest, and if you can find someone
                to help the two of you, it's really not that bad.
                Even the tools are limited, compared to a lot of jobs.
                One of the harder things is knowing what to keep and what to replace-
                you should plan on clutch, clutch slave, belts, hoses etc while you're in
                there, simply because it's so much easier.
                Honestly, while it's daunting as hell, if you're careful and work methodically,
                taking a lot of pictures and notes and cleaning as you go, it's really pretty easy.
                Go for it!
                hth
                t
                • Joe G
                  • 2942
                  Splitting car costs with a gf is not wise. Just sayin.
                  Current Car: 2011 BMW 135i, M-Sport, 6 speed
                  Originally posted by lambo
                  Sounds like you need a massage.
                  Originally posted by kpeng
                  Who the hell is Vlad?
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    I've found running driving e30s for $500.
                    Jussaying
                    • Wergen7
                      • Jun 2012
                      • 255
                      It's pretty easy. Seems more daunting than it is. And if you don't try you'll never learn. And if you fuck it up THEN you can go to a shop.
                      Bentley manual + Internet x R3v = anything is possible
                      http://www.r3vlimited.com/board/showthread.php?t=267166
                      http://www.r3vlimited.com/board/showthread.php?t=380488
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        This x1000 look at my build thread. Yea all that was done with the equation above except the welding of course internet can't teach you everything but what you don't learn from the internet you'll learn from just doing it and using your brain.
                        • blunttech
                          • 12850
                          true. first job I ever did on an e30 was a timing belt. 2 weeks later I tore the m20 out and did an s52 swap and full M3 5 lug swap. If youre mechanical its not hard. Im not a great mechanic. More of a unbolt something and replace it with something else. Youll learn a lot
                          sales@blunttech.com
                          www.blunttech.com
                          Like us on Facebook
                          • ST1G
                            • Oct 2012
                            • 6689
                            but they are in love!
                            Jussaying
                            QFT
                            I've learned how to work on cars purely buy trial, error, and throwing shit around when I'm pissed off and can't figure it out.
