Sand blasting!
  • blunttech
    • 12850
    I use black diamond as an all purpose media. Works well with dry air. But dont screw around. Be safe and get a GOOD respirator as stated earlier
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • plain325
      • Mar 2004
      • 163
      Originally posted by rcsoundn1
      I heard sand can cause silica which is some lung shit that is long term?
      • AndrewBird
        The Mad Scientist
        • 11892
        I've heard of many people using playground sand. They filter it through a screen first, and while it might clog up sometimes, is worth the slight amount of hassle considering it's so cheap.
        • ngampleh
          • Jul 2012
          • 466
          What kind of respirator that you used it?
          Brand and type maybe?
          [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
          [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
          Transaction Feedback
          • rcsoundn1
            • Nov 2012
            • 3361
            Thanks for all the replies, I am looking for a media that's not to expensive. I'll check the black diamond
            • Eddie Lives On
              • May 2011
              • 208
              50 pounds of the finer sand is what I use, $12.50/bag (canadian). It's the smallest sand they stock over here, and while it takes a bit longer to cover an area, the result is much more thorough and I don't have to go over the area multiple times.
              • rcsoundn1
                • Nov 2012
                • 3361
                do you use a respirator? if so how serious is it?
                  • 34827
                  get one of those cheap HF blast cabinets?
                  • ajackz
                    • Apr 2012
                    • 252
                    You need to be using a HEPA rated filter for your mask. The filter itself will be purple or magenta in color that is the proper filter for silicate particulates. You should take it very serious, however depending in your age it might not be too serious.
                    I'm cooler in person.
                    • Jaxx_
                      • Dec 2009
                      • 1880
                      I have used play sand to blast small parts, just because I wasn't about to spend real money on media that was going to be all over my lawn in a few hours. It's cheap and works fine. Ran it though a screen as stated and make sure it doesn't get wet or even damp. Moisture makes it much harder to use.
                      • rcsoundn1
                        • Nov 2012
                        • 3361
                        I tried the sand for a brief min, and it was a headache. Aside from that whole permanent lung damage info....
                        • eduTechnic
                          • Dec 2012
                          • 400
                          Quartz blast media at home Depot is $8 for 100 lbs. It hasn't clogged on me yet with the HF hopper. Even screened and dried playground sand was awful; never even got a steady stream.
                          Turbo M50 4 Door Build thread here 4 Sale thread
                          • rcsoundn1
                            • Nov 2012
                            • 3361
                            :firehop:off to HD i gooo
                            • rcsoundn1
                              • Nov 2012
                              • 3361
                              sux none of the box store have any media that I have been to
                              • REVunlimited
                                • Sep 2014
                                • 11
                                dont blast sand, it causes silicosis. which is very serious. i blast soda which seems safe(it wont harm your body if ingested) and is really nice only downside is not very strong. If the blasting job is tough then just put up the $$ to buy a blasting media which wont give you very harmful ailments if you inhale some particles which is likely whenever you blast!
