Help...broken key in ignition
  • fresh_TD
    • Aug 2013
    • 2457
    Half the key is broken in the ignition and the other half I have..I have second key for the car, I just need to pull the broken portion out..what's the best easiest/method for this? Any help would be appreciated..thanks
    Sent from my Samsung Note 3
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • Julien
    • 7471
    tiny drill bit. you affectively try to catch the missing section with the bit (by hand) and then pull it out
    Build Threads:
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Very small pair of needle nose pliers?
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • fresh_TD
        • Aug 2013
        • 2457
        Has anyone tried to do either method? and was successful
        • dnguyen1963
          • Nov 2011
          • 2649
          What position is the key in? If it is in the first then you should be able to pop the whole lock out. Otherwise, try to pry it out using two small, but strong pins or allen wrench.
          • jalopi
            • 2370
            I don't see either method going over well, especially if it's in there pretty deep.
            When I was 16 I worked for a locksmith as a summer job. I remember seeing him use these key extractors to get it out. Basically he stuck em in there, twisted each handle a few times and out the key came. Here's somewhere you can get em from
            Either that or you can call a locksmith and they'll remove the key for you. Probably cost $100 though.
            • BobombETA
              • Apr 2008
              • 1575
              Is it totally flush with the cylinder, or can you grab it at all? I'd try the tiny needle nose pliers
              Instagram
              Current: 99 M3
              Past: 84 325e, 84 528e
              • Liquidity
                • May 2014
                • 395
                Tweezers.
                • fresh_TD
                  • Aug 2013
                  • 2457
                  The key was just in there..I guess number 1? Steering wheel is locked..I'll take a look again to see if there's any portion sticking out that I can grab with pliers or something.. how about the glue method?
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    I'll check once I get home from work..this happened last night so I didn't bother with it then
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      I'm trying to avoid paying $100 for this, or whatever it may cost me ;-)
                      • glnr13
                        • 1334
                        2 paper clips with 1/16"-1/8" bent at the tips, insert one above the key the other below the key (vertically). you might have to get in there along the sides of what's left in there if it's all the way in at the hilt and then wiggle them up. the tumblers will allow the paper clips to slide through, just pull back once clips can grab onto a notch or two.
                        this worked for me on a beat up deadbolt, hopefully it works on a car ignition.
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          I'll definitely try this method...sounds like it would work..we'll see
                          • bradnic
                            • Jul 2012
                            • 3552
                            wow that's tough. good luck OP...
                            if the steering wheel's locked it's in the home position and the lock cylinder can't be pulled out.
                            after you get through this, get steel keys. That's what BMW and G-d intended for E30s. Brass keys suck, and they are what you get at a hardware store type place. They're just coated. If you take a magnet to the key and it slides off it's brass.
                            lots of good key info here
                            HOWTOs:
                            DB vert plastic bumpers
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              http://www.r3vlimited.com/board/showthread.php?t=332441
                              Thanks bradnic
