E36 318ti 5 speed on E36 325i motor??
  • DjSpeter
    • Jul 2013
    • 1
    I know this forum caters to mostly E30 chassis but I figure I can ask the question here. If not mods please feel free to delete or move. But here is my question...
    I bought a 95 318ti 5 speed recently and then I bought a 95 325i convertible with a blown transmission for 500.
    Could use the 318ti transmission on the 325i motor?
    If i can then what clutch and flywheel and pressure plate would I use?
    And what drive shaft would I use?
    And would the ecm throw a code and not run right?
  • TobyB
    • 5280
    Yes, trans should work. Depending on which one it is, it may be more or less good.
    But as to the rest- do you want a 2.5l ti, (yes, yes you do)
    or a working 'vert? (no, no you really don't)
    'Cause that determines which driveshaft to use.
    You'll want the 2.5l clutch etc setup.
    afaik
    t
    • Vtec?lol
      • Dec 2009
      • 3278
      the G240 will sit a few degrees off and you'll need the drive shaft from whatever trans you use.
      • E30NJ
        • Aug 2013
        • 921
        Whats wrong with the ti?
        • dirty30
          • 3048
          E36 TI uses a getrag 250 just like an e36 with an M50.
          • M-technik-3
            • 18946
            Not all some came equipped with G240. I have one that I parted for it, for my last Ti.
