Easy way to keep car from starting?
  • G FORCE
    • Mar 2014
    • 159
    I need to temporarily disable my 318is. In previous cars I would just pull the ECU fuse but I can't seem to find such a thing from the fusebox diagrams online. Any quick way to keep the car from starting? I pulled the fuel pump fuse but it still allows the car to start. Noob question but thanks for any help!
    Gabe
    '91 318is
  • brent5631
    • Jun 2012
    • 421
    Fuel pump relay, Pull battery cable, light it on fire...
    • TimKninja
      • 2131
      Fuel pump fuse
      Starter fuse
      Unplug engine DME
      1985 325e M50TU(Sold)
      1991 318is Slicktop (Sold)
      1990 325is Brilliantrot S50/5 Lug Swapped.
      1992 525i Manual shitbox Winter Beater
      • A.LACK
        • Sep 2006
        • 316
        Disconnect the battery
        Fuel pump relay
        Pull the motor out
        • Habla
          • May 2004
          • 1470
          Originally posted by A.LACK
          Pull the motor out
          Add some padlocks to the doors, too! That'll show 'em!
          -Peter
          318is slicktop | F15 35dM | F250 SD
          • G FORCE
            • Mar 2014
            • 159
            lmao! Sometimes I feel like lighting it on fire! However, for now I just unplugged the plug wires. Tomorrow I'll just pull the starter fuse. Didn't even see that!
            Gabe
            '91 318is
            • roguetoaster
              Biggus Tippus
              • 7830
              Install an automatics neutral safety switch, then break it.
              • Nick_S
                • Apr 2011
                • 3655
                Take the negative battery cable out.
                91 318is M50 swapped
                05 Honda Pilot
                24V swap thread
                • G FORCE
                  • Mar 2014
                  • 159
                  I thought about the negative battery cable but unfortunately the vehicle only locks when locking the trunk. Once I disconnect the cable, I can't lock the doors >.<
                  Gabe
                  '91 318is
                  • 3vilE30
                    • Jan 2013
                    • 344
                    Step 1: Remove Starter
                    Done
                    • itsonlygeorge
                      • Feb 2014
                      • 852
                      Disconnect the distributor from the coil. No spark.
                      1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
                      Originally posted by nando
                      I don't think there's really strong evidence that ZDDP harms cats.
                      • haggardfab
                        • Sep 2011
                        • 283
                        put a ford motor in it
                        IG: haggardfab
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          Why are you trying to disable it? But yea unplug the battery or just take the main relay out.
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • LivingLegend06
                            • Dec 2006
                            • 1604
                            Install a 13 button OBC and use the code feature.
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              Keep the key away from the ignition.
                              Originally posted by codyep3
                              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                              2001 silver/Blk 325 cabby. SOLD
                              2002 325xit Sil/blk. SOLD
                              2010 F650gs twin
