What would you consider a major fault with the E30's
  • redsubdivisions
    • Feb 2011
    • 1762
    M20.
    Hands down the biggest fault for North American cars.
    M40 for everyone else....followed closely by the M20.
    So you must dislike the engine that your 524td's powerplant is based off?
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • Massimo
      • Jan 2008
      • 3207
      Biggest Fault..
      Once you go E30 you can never go back.
      • Stanley Rockafella
        • Aug 2011
        • 4062
        age
        • pandaboo911
          • 2070
          Everything on the e30 was done proper except the steering rack.
          How has nobody mentioned that? The 4 turn LTL rack in the e30 is TERRIBLE. even the m3 came with that appalling steering rack. The e30 should've come with a 3 turn rack such as the e36.
          • rturbo 930
            • Dec 2005
            • 2626
            I thought the E30 M3 came with a slightly less appalling 3.7(?) turn LTL rack, but I might be wrong on that.
            • MonkeyMadness
              • 3251
              Biggest fault I have found of the e30 is the people who own and drive them.. There all a bunch of dicks...
              • Reichart12
                • Aug 2012
                • 2165
                Lack of cup holders? I know this problem comes up in threads occasionally. I can only keep a coffee cup wedge between the center console and passenger seat for so long before it spills a drop or two.
                Instagram: Reichart12
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  I've heard some good ideas, and I'd add the lack of an adjustable steering column as well. All the Mercs and Audis at the time had this feature, e30s did not.
                  Also no cup holders. I know Hans und Franz in 1983 were all like "No drinking on ze Autobahn! Das auto ist fur driving, nicht drinking!", but seriously, this is 'murica and we need those things...
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    M21 is fine only because it's a diesel.
                    M20 sux
                    • IronFreak
                      • Dec 2012
                      • 3702
                      M20 sux
                      Hater
                      Instagram @rebellionforge
                      • rzerob
                        • Jun 2013
                        • 2315
                        No arm rest.
                        • BobombETA
                          • Apr 2008
                          • 1575
                          Originally posted by BobombETA
                          Rear shock mounts breaking.
                          Shifter slop.
                          Battery tray rust.
                          Then all the problems remedied by installing e36 components:
                          Slow steering rack
                          Timing belts breaking
                          Periodic valve adjustment
                          4 lug
                          Overall, no major faults like DSM and Chrysler crank walk, Dodge truck rust, Tacoma frame rust, Subaru head gaskets, VR6 timing chain guides breaking, etc...
                          Duuuuuude. :)
                          Instagram
                          Current: 99 M3
                          Past: 84 325e, 84 528e
                          • IceWhite
                            • Jan 2015
                            • 945
                            The fact that when you take ownership of the car with the M20 motor, you have to do the Timing Belt/Water pump irrespective of what the PO says.
                            1990 325i
                            2004 330i Individual 6-speed
                            • bmw325_num99
                              • 684
                              I am definitely not understanding the hate for the M20. It is my favorite of the 3 US market engines although that might not say much. Great torque, smooth, fun to rev in the I version.
                              That being said, M50s are great.
                              2003 BMW 540i/6 M Sport
                              1997 M3 (sold)
                              1989 320i Touring (sold)
                              1990 325i (sold)
                              1991 535i/5 (sold)
                              1986 325es (sold)
                              http://etasport.tripod.com
                              http://s1353.photobucket.com/user/bm...library/Public
                                • Aug 2011
                                • 4062
                                Maybe in SA people are that untrustworthy.
                                In the rest of the world, if you have sufficient paperwork, it's good
