Stupid question but need to ask
  • liftedwj21
    • Nov 2014
    • 34
    So I have a 87 e30 lowered and going threw rear tears like crazy! Yes I know it happens when you lower the car. So on the e30 is there no adjustment for the rear? Don't need to go buy the set they make now or can I do any kind of adjustments to them to save some tire or am I SOL for now? Thanks
  • DrJosh
    • 2011
    How low are you?
    Originally posted by Sonny
    I am a meme for our community.
    • liftedwj21
      • Nov 2014
      • 34
      Think it's a two inch but was on the car when I got it
      • liftedwj21
        • Nov 2014
        • 34
        It's a eibach kit I believe
        • Mr. Tasty
          • Jul 2011
          • 3421
          E30's have a decent amount of camber in stock form. The only thing adjustable if stock is the front toe. There are weldable rear camber adjustments you can purchase.
          I go through tires every 12,000 miles, but those are 12,000 miles of full, rock hard chub.
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • DrJosh
            • 2011
            That is not abnormally low. I am on H&R races and have maybe 15k miles on my tires and a few track days. Even wear all around and tons of life left (320 treadware). I also have a LSD so maybe that helps keep down on ware from one wheel peels, that and I don't drive like a jackass on the road. You shouldn't be going through rear tires that quickly.
            • AndrewBird
              The Mad Scientist
              • 11898
              Your trailing arm bushings are likely shot causing excess toe. I'd start by replacing those.
              • liftedwj21
                • Nov 2014
                • 34
                Yeah just replaced the rear today and they were way worse then I thought! I'll get some bushing on the way any other ones I should so why I am doing it
                • liftedwj21
                  • Nov 2014
                  • 34
                  Heck if in going to go do that think I'll do the weld on tabs don't seem like to much more work
                  • DrJosh
                    • 2011
                    Might as well do rear subframe bushings as well.
                    • TobyB
                      • 5251
                      If you let them get too bad they WILL pope. And then,
                      shit, depending on what you hit
                      r3v will immortalize you...
                      Don't pope your tears.
                      t
                      • Stanley Rockafella
                        • Aug 2011
                        • 4060
                        qft
                        • gotane30
                          • Apr 2013
                          • 332
                          t
