timing belt broke when I was completely stopped, any hope?
  • Xecure
    • May 2015
    • 19
    I stopped at a light when I heard my engine just stall out. Is there any chance the motor will be ok? Or am I gonna have to swap motor/sell the car?
  • gr8skyr
    • 228
    pull the head, swap out the bent valves or any broken rocker arms, hope for no terrible piston damage, new HG, slap all back together with a conti timing belt kit, water pump, tensioner, cam seal gasket and your good to go for another 50k or 4 years, which ever comes first.
    "just love those little tanky inline 6's"
    • Xecure
      • May 2015
      • 19
      How can I tell if there is piston damage?
      • mr.vang
        • 4371
        Most likely the piston is not damage to the point where it is not useable. You'll see just some mark on top of the piston. If it is cracked then it is no good.
        • gr8skyr
          • 228
          And by "slap" it back together, i mean follow Bently manual specs, use new head stud bolts, torque correctly. There is a fully rebuilt "885" head just posted here for about $950. You could grab that and you'd about plug and play on this job. You could then rebuild your head and resell at your leisure. Also you want to make sure your timing is checked and double checked. You don't want to be off one tooth and do all that work only to do it over. Didn't want to sound to cavalier in doing a correct timing belt/ head gasket job. It's the time to do your waterpump if you don't know last time done while it's all apart, serpentine belts too.
          • SkiFree
            • Jun 2011
            • 2766
            and.... as I hate to point out, but timing belts don't just "break" without having been neglected far past its servicing date/mileage. It's a tough lesson to learn.
            ADAMS Autosport
            • Xecure
              • May 2015
              • 19
              I purchsed the car about 3 weeks ago.
              • UlrichFennec
                • Dec 2014
                • 1268
                Do you have any records of the last time the belt and tensioner were changed?
                "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
                http://www.r3vlimited.com/board/showthread.php?t=366044
                The stickers make it go faster. :nice:
                • Xecure
                  • May 2015
                  • 19
                  I have no records of any maintenance. I was planning on doing it either today or tomorrow.
                  • TurboJake
                    • 3780
                    There's a very slim chance. I've seen it happen personally with an M20, but the gods pretty much have to favor you, your family (Including cousins, uncles, aunts, and grandparents), and every single guy or gal you've ever been with for it to happen. It's grossly more likely that it did get damaged. We're talking lightning striking you or winning lottery odds here.
                    Pull the head and inspect.
                    Leave Me Transaction Feedback
                    • ST1G
                      • Oct 2012
                      • 6689
                      Facts right there.
                      • Exodus_2pt0
                        • 5943
                        I've seen valves bent from the machine shop sitting an m20 head on their counter waiting for me to pick it up.
                        No E30 Club
                        • UlrichFennec
                          • Dec 2014
                          • 1268
                          The Achilles's Heel to E30s with an M20 is the timing belt and the cooling system. Praise the BMW gods for letting me change my timing belt every 20,000-30,000 miles without hassle.
                          • Stanley Rockafella
                            • Aug 2011
                            • 4062
                            yup, heard that before
                            • Xecure
                              • May 2015
                              • 19
                              Thank you for the helpful comment
