Shop Replaced WP timing belt. Now wont run for s&it
  • txtorquemade
    • 1758
    Let a shop do my timing belt on 90 325i. I just didn't have the time to do it this time. Got the car back. Ran kind of iffy from the shop, but it did run. Was running kind of bad anyway, so I ordered electrical tune up parts, cap/rotor/plugs/VCG...etc.
    After one cold cycle, car wont idle, runs, but only after holding the gas to get to it warmed up to near drive temp.
    I think the dicks at he shop got the timing belt a tooth off? Any thoughts or method to confirm this without pulling tearing the timing case down again??
    Thoughts??
    sigpic 1987 325is
  • sneakyRedPanda
    • May 2015
    • 133
    Just take it back to the shop...
    • navytapaul
      • 615
      ^that
      They didn't do the required job, so take it back.
      • jhaurimn
        • Nov 2012
        • 2224
        If you bring it back to the shop, dont mention you worked on the car yourself since they last did. Otherwise they will claim you messed something up with the parts you installed.
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • 5Toes
          • 9836
          it probably is a tooth off on the timing. good luck bud!
          • Project535
            • May 2011
            • 73
            +1. Most places will jump at the chance to shift blame. Don't give it to them. Just mention it hasn't run right since you picked it up, no further information necessary.
            1992 325I Convertible
            • long tall eta
              • Jul 2010
              • 1536
              they probably didn't take the time to rotate the engine a few times to check for alignment.
              • Exodus_2pt0
                • 5943
                Hopefully they didn't mess it up bad enough to nick a valve.
                Whatever happened, they either know what they did or will know. Don't let them talk you into spending more money to fix it.
                No E30 Club
                • Ceeker
                  • Sep 2009
                  • 2821
                  ^^^^ get an diagnostic done from another reputable bmw shop or dealership before taking it back but don't tell them. That is your proof they screwed up. If they are reasonable about it then you leave the est out of the equation. If they are not then you flip the est in their face and tell them "they screwed up" then go from there. Just be prepared for the ugly side to rear it's face.
                  • TimKninja
                    • 2131
                    Cap and Rotor not tight? Or if they fucked up mounting any of the timing cover stuff.
                    Accidents happen.
                    1985 325e M50TU(Sold)
                    1991 318is Slicktop (Sold)
                    1990 325is Brilliantrot S50/5 Lug Swapped.
                    1992 525i Manual shitbox Winter Beater
                      • 37829
                      When you pay a professional for a service and it was not completed correctly, you take it back.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • KIRIEIW
                        • Dec 2012
                        • 3385
                        As far as I know one tooth off will make contact with a piston?
                        1992 e34 Touring- S50 Swap
                        1992 325i-S50 Swap (SOLD)
                        1991
