Dumbest mistake youve made with your e30?
  • Exodus_2pt0
    • 5943
    Originally posted by jalopi
    302 swapped my car
    I concur. Kept mine for only a few months after.
    No E30 Club
    • shedby_budwin
      • Apr 2013
      • 84
      Wrecking it :( But I'm working at a bodyshop now so I can bring it back.
      It's not bad paint, it's called "patina"
      • Wschnitz
        • 8089
        I have also gone through the no gas debacle op, replaced a bunch of stuff before tapping the bottom of the tank and hearing a nice echo.
        Driving with summer tires on ise.
        willschnitz
        • marshallnoise
          • Sep 2013
          • 3148
          I'd be interested in the 302 swaps being a downer. How come?
          Dumbest thing I did, in retrospect, is starting to drill spot welds and rip out frame work. I should have just taken it to a frame shop.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • pbsun
            • Jul 2011
            • 97
            After cleaning the far ends of the parcel shelf with a long pointy vacuum extension while maneuvering the extension out of the car poked a nice hole in the once flawless headliner.
            • pandaboo911
              • 2070
              put a 500whp supercharger kit on my daily driver
              • marshallnoise
                • Sep 2013
                • 3148
                That will do it.
                I put solid different bushings on my daily driver cobra. Ruined the car.
                • Exodus_2pt0
                  • 5943
                  Mine came with problem after problem. Biggest being a severe driveline vibration that I could not find. Trans came out over and over. Eventually I just decided that it wasn't making enough power to deal with all the little headaches.
                  It was great for turning heads, and was relatively quick, but a turbo m20 is the way to go.
                  No E30 Club
                  • cabriodster87
                    • Jan 2011
                    • 1042
                    I had my hood upside down on top of the car, lifting car with a floor jack caused freshly waxed hood to slide straight on the floor.
                    Reich und Roll!
                    • HersheySquirts
                      • Apr 2014
                      • 119
                      Deciding to replace the front drop link brackets when I did new links/bushings. Snapped a bolt while torquing to spec so I go inside swear a few times and ordered a new one. Stupid me should have ordered the other side because the next night I snapped the other bolt. I thought I might have been putting uneven pressure on the bolt so it snapped but they were so old they snapped with only 10lbs on them. So I ordered the other side. Go back to double check the rears, snap another... 3 separate orders within one day for $7 parts. Not a stupid thing I did to the car, just me being stupid lol. Glad I replaced them though, serious safety hazard.
                      • 613EDRTY
                        • Apr 2014
                        • 267
                        I once forgot a jack stand under my car when I was fitting some side skirts....dropped it right on the fuel pump...such an idiot. My friends response....smoke another one bud...lol
                        Rescued 1986 325e Coupe
                        1988 325ix Touring 5spd currently being rescued
                        Ottawa, Ontario, Canada :finger:
                        • BobombETA
                          • Apr 2008
                          • 1575
                          Not respecting it's lack of ground clearance after I lowered it... Cracked an oil pan and ripped the boots on my power steering rack in separate incidents...
                          I probably made a lot of mistakes wrenching on it too that i can't remember, but it was the first car that I really learned on.
                          Instagram
                          Current: 99 M3
                          Past: 84 325e, 84 528e
                          • cwatt
                            • Oct 2012
                            • 275
                            Buying it.
                            • cwatt
                              • Oct 2012
                              • 275
                              Originally posted by ncsubowen
                              In for a penny in for a pound I suppose - at least when it's done you'll have the sweat equity to keep you from turning around and selling it :)
                              That's not sweat equity, that's sweat deficit.
                              • Mr. Burns
                                • Aug 2011
                                • 3516
                                ripping out a perfectly healthy and solid engine and drivetrain to take on an engine swap...so far it's been fun/frustrating but i'm facing way more downtime than I had originally expected.
                                Everyone is out cruising in their summer cars, and i'm here with my e30 vert on jackstands test fitting driveshaft measurements while I still gotta install an entire wire harness...
                                don't fix what's not broken.
                                ^^^listen to this saying^^^
                                oh and two years ago had a no fuel issue with my e30 for a couple of weeks.
                                tore everything apart only to learn the gas tank was empty.
                                added fuel, fired right up lol
                                Originally posted by flyboyx
                                i have watched my dog lick himself off a few times
