Need to bring e30 out of 4 year storage
  • eek142
    • Apr 2009
    • 78
    Got an '89 325i that hasn't been started in almost 4 years. I plan to change the oil and drain the cooling system, but what else should I be doing to make sure I don't destroy the engine when I crank it the first time?
    Should I treat the gasoline somehow to separate out any condensation that may have built up? Should I take out the plugs and squirt some oil in there?
  • Todd Black 88
    • Oct 2007
    • 3449
    I would personally drain the fuel and put new in.
    The stuff in the tank will be separated and shit now. It will gum up everything.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • eek142
      • Apr 2009
      • 78
      I think that's a good idea. Going to jump the relay and pump it out.
      • Keith M
        • 2338
        Change the timing belt.
        • punnzzells
          • Aug 2005
          • 333
          I'd do a full tune up for sure. I would also drain the fuel and replace it with a half tank or more. I would also turn the key to the start position and let it sit for 5-10 seconds each time...I would do this at least 4 or 5 times before I even cranked it over.... oil pump and fuel pump need to come on and off in order to prime the lines.
          also, I would change the brake fluid and most likely, if you left it stored with e brake, its seized.
          • Keith M
            • 2338
            You can pull the injector relay and crank it to pump up the oil pressure.
            • punnzzells
              • Aug 2005
              • 333
              yes, keith... but if the motor's been sitting for 4 years... how much oil's really covering the vitals?
              If you turn the key a few times to the on position, before cranking it, the system will have a few seconds to prime before a crank. I'd rather have a few squirts of oil on my internals before I crank.
              Just my opinion..
              • Keith M
                • 2338
                It's a mechanical oil pump. Turning the key on does absolutely nothing.
                • atldohc
                  • Nov 2008
                  • 359
                  :rofl:
                  • Wolfman
                    • 341
                    Or pull the drain plug on the gas tank under the passenger side
                    • kickinindian
                      • 2327
                      take off the valve cover and pour oil on the cams and rockers if your so worried about it...
                      • estoguy
                        • May 2013
                        • 1087
                        What previous posters said... change the fuel completely (I'd change the filter too), oil change, timing belt (water pump too if it's time - should be done every other change), and accessory belts. You might want to do some coolant hoses if they've been in over ten years too.
                        Estoguy
                        • TobyB
                          • 5280
                          At 4 years, I'd do the timing belt.
                          I'd pull the spark plugs, too, and crank the engine until I saw oil pressure.
                          And given the crap that came out of the parts car fuel system, I'd pull the fuel line
                          and let it flush itself. And change the filter.
                          but that's me.
                          t
                          • GDA
                            • 446
                            I just got a motor running that had not run in close to 8 or so years....
                            Pull plugs and give each cylinder a squirt of oil or marvel mystery oil
                            Drain fuel tank and fill with fresh fuel
                            Change oil and filter
                            Pull fuel pump fuse and bump the starter a few times to prime the oil pump
                            Reinstall fuel pump fuse and put in fresh spark plugs
                            Fire it up and let it come up to operating temp
                            Agree with others.... change coolant, brake fluid and timing belt
                            Given its been sitting, you might have to clean ICV and get fuel injectors professionally cleaned as one or more might be stuck, plugged or leaking
                            • steve68
                              • Jan 2013
                              • 457
                              ^^^^^ this, most important is oil circulation on all bearing and contact surfaces,
                              88 M3 Lachsliber glass top, 90 IS project,
