Bad ass pressure washer at work. Can I wash a GETRAG 260 in there?
  • scarecrow
    • Apr 2013
    • 45
    My new brand used transmission has 20 years of oil and dirt on it. It needs to be cleaned. Im thinking the trans is pretty water proof and can be washed. What do you guys think?
  • Wschnitz
    • 8089
    Id just try and avoid the seals, ive done it before, but i checked for water inside afterwords too.
    willschnitz
    • Stanley Rockafella
      • Aug 2011
      • 4062
      Here I was expecting to see a pressure washer with a getrag 260 built into it
      OP should rephrase thread title
      • blunttech
        • 12850
        seal the breather on top if you must. Id personally do it with degreaser and brushes
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • jrobie79
          • Mar 2006
          • 2526
          I used a pressure washer on my G240...cleaned it up real nice...i did plug the breather and i was replacing the seals, other than that i left it outside in the sun for a day with the plugs open in case there was any water residue inside
          1991 318i ---- 308K - retired
          • slammin.e28
            שמע ישראל
            • 12054
            Wear a rubber smock and face shield.
            Or don't, and wish you did.
            • steve68
              • Jan 2013
              • 457
              what he said^^^^ and Purple Power is your friend!!!
              88 M3 Lachsliber glass top, 90 IS project,
              • AndrewBird
                The Mad Scientist
                • 11898
                Fun fact:
                Getrag designed the trans in a way that any water sprayed at it is reflected directly at your face.
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  ^ this is so true
                  1991 325i - "Scambles" The Daily Driven lightly modded.
                  1988 Mazda RX-7 TII "Mako" The Free Dorito
                  bacon by Jared Laabs, on Flickr
                  • marshallnoise
                    • Sep 2013
                    • 3148
                    Stuff works great, but etches the shit out of aluminum. So be careful with how long you leave it on.
                    Si vis pacem, para bellum.
                    New Hawtness: 1995 540i/6 Claptrap
                    Defunct too: Cirrusblau m30 Project
                    Defunct (sold): Alta Vista
                    79 Bronco SHTF Build
                    • steve68
                      • Jan 2013
                      • 457
                      so does Simple Green, but its a trans, some etching wont hurt, now using it on a set of polished RS's, to the stocks with you!!
                      • 5Toes
                        • 9836
                        I pressure wash differentials quite often and even without the breather plugged water never gets in there. Leave the fluid in the trans and drain it after you pressure wash it, inspecting it for water in there.
                        • totheredline
                          • Jun 2013
                          • 762
                          I've pressure washed a 240. No issues
                          = Heidi 1988 325 -> 335i. 7200rpm built M30
