old momo shift konb stuck...
  • Myself
    • Jan 2015
    • 46
    I have a very beat momoshift knob I want to replace with just some plastic bmw knob but the damn thing is stuck on there
    DOES NOT APPEAR TO
    1) bop it
    2) pull it
    3) twist it
    NOTHING WORKS! help please, I've heard there is allen screws at the black ring thing but the knob itself does not budge at all. I've lifted off the boot and when i pull or twist it seems to want to tear a hole in the boot under the housing
    here's a pic of the stubborn asshole
  • kid325e
    • Sep 2007
    • 6421
    Twist that black piece counter clockwise. When you unthread that piece, you should see three allen set screws. Loosen those and the knob should slide off.
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • Myself
      • Jan 2015
      • 46
      i'll give it another go with a pipe wrench this time lol
      thanks
      edit: no luck, any other ideas?
      I've essentially stripped the black ring 1/4 the way thru almost looks like just an aluminium ring now =\
      also the shifter wants to turn with it even if I try to hold it down, I'm having a weird paranoid feeling it might blow out a syncro or the linkage if i keep going at it. whole thing might turn 180 while the damn knob still stuck there laughing at my ass
      • XwalkerX
        • May 2015
        • 383
        honestly I had the same knob in my e30 when I bought it (its on ebay now)
        the black part that says momo will unscrew and there are 3 allen set screws
        • Myself
          • Jan 2015
          • 46
          is it possible my ring is seized?
          damn, gotta spray some lube... ugh gonna have a drippy mess to deal with getting onto the boot,wood, under console.
          edit: got none in the household... now I have a really janky looking knob with scratched up momo ring. Hopefully I didn't torque out any bushings or small components under the shifter
          Does the entire shiftknob + ring turn together? If so, I'm thinking about using 3 tools to clamp and turn them all simultaneously but on the other part of my thinking it might cause everything under the shifter to explode
          • AndrewBird
            The Mad Scientist
            • 11897
            Hold the shift knob, turn the ring. Looking from the top, you turn the ring clockwise. The ring will unscrew downward from the knob.
            If you hold the knob and turn the ring, the shift lever should not turn.
            • Exodus_2pt0
              • 5943
              The sleeve unscrews separate from the knob.
              No E30 Club
              • kid325e
                • Sep 2007
                • 6421
                When you say pipe wrench is this what you mean? Channel Locks always help me out in situations like these.
                One with long handles to help with leverage will make it a ton easier then also the longer the handles the easier it is to get a really good grip on it. Don't be a waffleswaffleswaffleswaffleswaffles dude, be stronger than that shift knob.
                clutchCTRL!
                - 2000 323i AT
                • AndrewBird
                  The Mad Scientist
                  • 11897
                  ^^^Those are water pump pliers. This is a pipe wrench:
                  • Myself
                    • Jan 2015
                    • 46
                    got it finally on latest attempt went with ease, must have been loosened over all that raging I did earlier lol hopefully the rest of the shifter assembly is doing ok
                    edit:
                    - and thanks for the quick responses
                    - Yes, was clockwise not counter clock (for this one in particular atleast)
                    during my search prior to posting here, I did come across this
                    Pictures are broken for me but it seems that he literally sawed his shift knob off to install another
