How many of you guys actually do work on your own car?
  • RCWells
    • 3589
    #31
    To date the only thing that I haven't done is A/C work, and most likely that will not change. I've got to have some more A/C work done now and I'll do what I can of it, but the charging will be left to the pros.
    Next up?
    A/C drier, hose, r12 recharge
    Clutch replacement
    Timing belt/water pump
    All hoses/belts
    New plug wires/rotor/cap/etc
    Brake rotors/pads/New master cylinder(25mm)
    Motor mounts
    New oil pan?or repair w/some JBWeld
    [THE 501 club - Founding Member]
    • FredK
      • 14762
      #32
      Originally posted by Eric Giles
      I let it drain until there is absolutely nothing coming out of the drain hole before I put the plug back in.
      Yeah, I usually drive the car for a little while to warm up the oil, which also adds a bit of time. I probably wait around 5 minutes for the oil to drain, and while that's happening I do the filter and wipe down parts of the engine bay that have accumulated dirt and dust.
      Befo' you slam it, Fram it. Just kidding.
      • madjurgen
        • May 2005
        • 1203
        #33
        dont buy an e30 if youre not going to do your own work. its just silly. even if youre rich.
        wtf, an oil change takes 20 min tops.
        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
        • AndrewBird
          The Mad Scientist
          • 11898
          #34
          I think the question should be, "Who doesn't do all their own work on their car?" :)
          • modifiede30
            • 1208
            #35
            I'll do it all in my driveway, but I have access to a lift 20 ft away, so I don't have much to worry about.
            Driving is the only way to go faster....
            • shiftbmw
              • Oct 2005
              • 2012
              #36
              I do work on mine...valves, fluid changes, radiator, anything. Haven't had to do a whole lot on the e30 though.
              Used to drop trannies, do clutches, differentials, whole bunch of crap when I owned Datsuns.
              "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
              • erik325i
                • Jan 2005
                • 3567
                #37
                I do all my own work.
                When I first got my e30, i barely could change my own oil. Now, I do everything including replacing my clutch, entire suspension, installing/balancing tires, allignments...
                I also work on my GF's e30, help my brother with his e30, work on my mom's e46, and help out fellow e30 owners.
                -Erik
                • kommissar
                  • Dec 2005
                  • 402
                  #38
                  I just did some scheduled maintenance a couple hundred miles ago. From what I remember I did:
                  Spark Plugs, dist. cap, rotor, water pump, all new hoses, coolant flush, all new belts, oil / oil filter change, and the timing belt.
                  I wanted to do the cam shaft oil seal while I had the distributor off but I didn't. I think that it needed a Torx wrench to get in there or something.
                  • MitchFong
                    • Sep 2005
                    • 665
                    #39
                    my e30 has not seen a garage since i bought it.
                    so far i have swapped my full suspension minus sway bars. Which will be done soon. Changed oil, all fluids, spark plugs, dist. cap, and im sure much more as time goes on. Need an allignment tho, i dont think i can manage that one. And ill need a shop to build my exhaust as i cant weld, nor have a welder.
                    • AdironRider
                      • Dec 2004
                      • 3491
                      #40
                      The only time my e30 sees a garage now is when Im stuck in a pinch or for inspections etc.
                      Back to my roots
                      • 87Blue325iC
                        • Apr 2006
                        • 1111
                        #41
                        Nope, never worked on my car...
                        Aaron
                        • e30vert
                          • Jan 2005
                          • 1789
                          #42
                          I typically dont work too much on mine either.
                          NOT!
                          • 92 mtechnic cabrio
                            • 4907
                            #43
                            Originally posted by E46toE30
                            My concern with full suspension work is the major $$$ id have to spend on special tools. Wouldnt you need a spring compressor to do jobs like that?
                            You can get a pair of cheap spring compressors at harbor freight that get the job done for $10
                            R.I.P 07/01/09 - 04/23/10 :(
                            • AdironRider
                              • Dec 2004
                              • 3491
                              #44
                              Yeah man spring compressors are cheap. Plus there are plenty of parts places around that would even rent those special tools to you for cheap.
                              Back to my roots
                              • ///M42 sport
                                • 3952
                                #45
                                Oh, just the usual 5spd swap and oil pan gasket. nothing major really.
