My old friends dad is selling his E30...
  • Krisperr
    • Oct 2014
    • 9
    http://www.kijiji.ca/v-classic-cars/...ationFlag=true
    It's been stored for 15 years so I'd imagine all the rubber bits will need replacing. He took it out of the garage and everything seemed fine, I'm just hoping it will make it back the 40 minute drive. I've been looking for one forever and considering this is 1 of maybe 5 on the island, I figured it's worth jumping on.
    Being said, is there anything I should know about the 325e? I will more than likely be doing a swap in the future anyways, but right now I'd like to just clean it up.
    I've also been told the interior is the blue houndstooth and it's fairly rare, and an mtech 1 wheel.
  • Grackle
    • Jul 2015
    • 119
    Depends on if he started it occasionally in that last 15 years or not. The tires will be a risk to drive on at the very least.
    • slammin.e28
      שמע ישראל
      • 12054
      That 15 y/old timing belt it probably pretty crispy.
      • rcsoundn1
        • Nov 2012
        • 3361
        Can I get those seats and front lip............
        • DrJosh
          • 2011
          I would not start that (let alone drive it 40min) without doing a timing belt at the very least.
          Originally posted by Sonny
          I am a meme for our community.
          • Rouvld
            • Sep 2014
            • 569
            Like others have mentioned do the timing belt. At the very least Id do the belt, brakes and new tires. Before I drove it.
            • Stanley Rockafella
              • Aug 2011
              • 4062
              Strange, I sold my 86 325es with the exact same front spoiler setup as this car, back in 02ish to a guy in Lethbridge AB. Aside from the letters and numbers on the back, it was EXACTLY the same car....same houndstooth sport seats too.
              I regretted selling that car since I really liked it. Boy that was long ago
              • rcsoundn1
                • Nov 2012
                • 3361
                here is your chance to buy it back
                • Krisperr
                  • Oct 2014
                  • 9
                  In my excitement I completely forgot about the belt...
                  The brakes are apparently fine but obviously I'll have a look all beforehand. If I had access to a trailer this would be great.
                    • Aug 2011
                    • 4062
                    naw, this is on the other side of Canada, and mine had a bit of hidden rust.
                    I wouldn't want it back. too many "projects" on the go anyway
                    • rturbo 930
                      • Dec 2005
                      • 2629
                      Rent one?
                      From what you're saying, and your location, I think this is your best shot at an E30, if it's as clean and rust free as it looks. I'd jump on it if I were you, and then figure out how to get it home.
                        • Aug 2011
                        • 4062
                        Is that cosmos or cirrus?
                        • Krisperr
                          • Oct 2014
                          • 9
                          That seems to be the way it is. I'll check the belt, if it's dry rotted I'll just haggle a bit off of him and do my best to get a trailer to bring it home. Hopefully this works out tomorrow.
                          • DrJosh
                            • 2011
                            2k is nothing. Don't be a dick. Just get a trailer and tow it home.
                            • 101
                              • Jul 2011
                              • 764
                              If this car has been regularly started and moved around a bit, you'll be a bit better off than if it has been truly stored the entire time.
                              I can't stress enough - DON"T drive it! In fact, I wouldn't even start it again.
                              How old is the fuel? If unknown, assume it has to be drained and fresh fuel put in. And a new fuel filter fitted immediately.
                              The fuel hoses may be old and brittle. With pressure applied after being dormant for 15 years, pop goes the line.
                              The brake fluid will certainly in need of immediate change, and the calipers may be sticking from moisture in the system.
                              Ditto for the coolant. It's old and won't have optimum characteristics.
                              The engine oil seals may have hardened and taken a set over time. Oil leaks are common after years of inactivity.
                              The tires may seem fine but at 15+ years will have hardened and will not have any grip whatsoever on a wet road. I'd bet there's cracking in the bottom of the treads as well which could be a blowout risk.
                              Last but not least, that timing belt is a ticking time bomb. Its not a matter of IF it will break, just how soon it will.
                              How do I know these things? I've been bitten by EVERY ONE of them.
                              She's a pretty car and has great potential. Don't screw it up and try to drive it home.
                              101
                              The E30 collection:
                              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                              1987 325is - Delphin / Black Sport (son #3's)
                              1987 325i Convertible - Triple Black
                              1989 325iX Coupe - Diamondschwarz / Black Comfort
                              1990 325iX Coupe - Sterling Silver / Grey Sport
                              1981 Fiat 124 Spider 2000 - Green / Tan
                              1998 Volvo V70 GLT - White / Tan
                              1998 Volvo S70 T5 manual - White / Taupe
                              2001 Ford Windstar - Silver / Grey (parts hauler)
                              2006 Lexus GX470 - White / Tan (tow rig)
