325ix brake master cylinder vs e34 535i brake master cylinder
  • AlpinaB3
    • Oct 2012
    • 312
    I need to know if the e34 535i brake master fit in the 325ix booster. 325ix bmc is quite expensive and seems that the e34 535i is the same. Anyone can confirm that?
    6psi 224hp/260tq
  • Northern
    I like cupcakes & sh!tboxes
    • 5270
    Not the same part number on realoem.
    Originally posted by priapism
    Originally posted by shameson
    • Northern
      • 5270
      but this shows that the same booster was used on some E34's and some E32's, so their masters should fit, although they may be different sizes.
      http://www.realoem.com/bmw/enUS/part...&q=34331161486
      • AlpinaB3
        • Oct 2012
        • 312
        Yes, 325ix, e34's and e32 use the same booster. So im trying to corroborate that the master cylinder of the e34 and e32 will work on 325ix.
        6psi 224hp/260tq
        • TurboJake
          • 3780
          Cannot confirm, but what I do know that you can use the master cylinder from early 90's 190e's with a slight brake line change on the front port. 2.3 and 2.6 have different bores, but the 2.3 7/8" bore is nearly identical to the 325ix.
          Leave Me Transaction Feedback
