Airbag car steering column questions
  • E30budget
    • Mar 2015
    • 512
    Hey all, I have a 1991 318is with some steering column issues and I cant find a definitive culprit online from old posts..
    So I have a rattle when I hit bumps, low or high speeds, or even turning the wheel
    The steering wheel is indeed tight on the splines and column
    I pulled the kick panels and the lock collar nut is tight, the guibo is squishy but not torn up (will be replaced soon with solid AKG)
    When I put my hand on the column rod where it runs through the firewall it has play through the firewall, is that supposed to be like that? I read there is only one bearing for airbag cars..
    Where it goes through the firewall is there a bushing or a bearing that holds it and it supposed to have a little play?
    • 34839
    check the U joint near the steering rack. They do wear out eventually.
    There's no bushing in the firewall that I know of, just a rubber grommet.
    • e304lyfe
      • 807
      It might be the upper steering assembly underneath the dash with the telescopic splined shaft with the large nut. In my case, even though the nut was tight, the splined shaft was worn and would rattle over bumps. It was hard to isolate noise to this component, and I went through replacing the lower u-joint and steering rack before concluding this part was the culprit.
      This whole assembly is available new from bmw. Part #: 32311159500 FWIW I similarly did not find much information from people with this problem when searching online.
      • AwakenNoMore
        • Dec 2010
        • 1291
        '91 former airbag car here too. Mine rattles a little too, I just kinda deal with it.
        1991 325i - "Scambles" The Daily Driven lightly modded.
        1988 Mazda RX-7 TII "Mako" The Free Dorito
        bacon by Jared Laabs, on Flickr
        • audiquattrot
          • May 2008
          • 3836
          there is also a small steering guibo underneath the dash. But like nando said, I would replace that u-joint. Also that large nut on the column (by the pedals) is notorious for coming loose. find a wrench to hold that nut, and turn the steering wheel (clockwise?) to tighten.....that should def help if there is play there. Just had to do it a couple wks ago on mine again b/c of rattle....I might put locktite on it to be sure it doesn't back itself out.
          www.instagram.com/snwmble
          #snwmble
          Current:
          '05 BMW M3 - Silver Grey/Imola Red
          '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
          '15 Mini Countryman - Blazing Red/Carbon Black
          Past:
          '01 Audi Allroad - Light Silver/Platinum Saber Black
          '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
          '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
          '90 BMW 325i - Schwarz/Tan sport *Sold*
          '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
          • E30budget
            • Mar 2015
            • 512
            Thanks a TON for the info fellas. If this doesnt work ill buy a new column as they arent THAT bad..
            • Dust2glory
              • Sep 2015
              • 25
              My 91 318is does the same thing. I'll be very interested in the results but I'll take a look at mine tomorrow and see what I can find.
              • steve68
                • Jan 2013
                • 457
                my air bag car does the same,
                88 M3 Lachsliber glass top, 90 IS project,
