polyurethane motor mount experience, why check your mounts??
  • wilholl
    • May 2012
    • 518
    Just to inform and not to slam any particular design.
    Polyurethane mounts can be found practically everywhere and many accept them as better than original rubber
    And they are sometimes installed because race car or the owner will feel less concerned about breaking things when driving spirited or hard.
    installed 6 years ago
    and a torn subframe
    I dont't think I drive that hard!!
    So glad I have a new reinforced subframe to install later.
    Installed OEM rubber mounts for now
    And back to business!!
    Clean up on isle.....????
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
  • ButtJuice
    • Dec 2009
    • 2609
    Same thing happened to my friend's e28 trans mounts, lol they were the same color as well.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
    • Mr. Burns
      • Aug 2011
      • 3516
      Pm sent. Those mounts look too familiar...
      Originally posted by flyboyx
      i have watched my dog lick himself off a few times
      • ak-
        • 12422
        6 years ago. This I.E.?
        1991 325iS turbo
        • Exodus_2pt0
          • 5943
          How were your other mounts?
          There's a reason no one uses poly for control arm bushings, or areas that are subject to actual movement. (The exception would be race cars that aren't used all the time, or people who don't know better.)
          If these were subject to impact or excessive movement, then that's why this happened. Loose nut maybe? Once it had some free play, the constant bashing from the engine loading/unloading the mount would explain why it completely disintegrated.
          No E30 Club
          • flyboyx
            • 8371
            looks to me like the plastic deteriorated and disintegrated. probably due to heat in the engine compartment.
            what do you suggest someone use instead?
            Gigitty Gigitty!!!!
            • Exodus_2pt0
              • 5943
              I'm all for poly drivetrain mounts, subframe bushings, just area that don't move.
              They shouldn't have disintegrated like that in this application, but even still, 6 years isn't a bad life span.
              No E30 Club
              • wilholl
                • May 2012
                • 518
                PM replied
                I am not trying to slam anyone's product. Basically all polyurethane mounts are subject to the same issue.
                The other mounts are beginning to fail as well. This one is the worst.
                No loose nuts... just the driver!
                This is the mount closest to the exhaust manifolds. The heat shield was installed and intact. This mount is also subject to the most torque from the motor pulling on it and I agree that once it began to fail, the up and down movement, when on and off throttle, would grind the mount into little pieces.
                The idea of this thread was to let community know what can happen if you use these mounts and you don't periodically check and replace.
                Can other mounts do a better job and or last longer?
                Sure, nylon, delrin, solid, even OEM rubber might last longer.
                For myself, I am wondering if stock rubber might not be so bad even in hard driving conditions as long as they are not worn out.
                Also, don't forget!! Harder mounts=torn subframe, if not reinforced
                • Exodus_2pt0
                  • 5943
                  Also I'm not seeing the damage to the subframe. The opening looks intended. Maybe I'm not looking in the right spot?
                  No E30 Club
                  • Kershaw
                    • 11822
                    Yeah, I don't see any tearing. But it's been so long since I've seen a RWD front subframe I can't really be the one to say anything.
                    AWD > RWD
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      There is daylight to the right of the LCA mount which goes through the subframe.
                      Was just pulling mine out today... still am.
                      ACS S3 Build / Dinan 5 E34
                      • ak-
                        • 12422
                        Well reason I ask is because I have two friends who had the same issue on the same side with the same product.
                        IE said they've changed the design since, though, so just curious considering yours is 6 years old in the same timezone of when they were selling them.
                        Heck, one of my friends even worked for them at the time of his failure.
                        1991 325iS turbo
                        • djmossm42
                          • Jul 2012
                          • 687
                          I'm sure although they may be more durable than rubber they aren't truly a lifetime product. Based on your experience what's the real world lifespan for a street/track car with poly bushings? Are there intermediate checks that can/should be done to get more out of them?
                          Sent from my MI 4LTE using Tapatalk
                          Wheelwell
                          Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
                          LED Bulb Thread
                          R6 LED Review
                          • wilholl
                            • May 2012
                            • 518
                            PM sent
                            • b*saint
                              • 3794
                              Ill never run those. There's a reason they are rubber from BMW!
                              Ma che cazzo state dicendo? :|
