No Proper Size Tires?
  • Mr. Wolfe
    • Jul 2014
    • 540
    It seems there is no proper sized tire for a 16x8 and 16x9 setup or 16x8.5 and 16x9.5. You cannot get a matching diameter.
    For instance, you can find a 205/45/16 (23.3" diameter), but no matching 235/40/16 (23.4" diameter)
    Is this why everyone stretches the hell out of their tires?
    Mr. Wolfe
  • rcsoundn1
    • Nov 2012
    • 3361
    no its not why.
    • Mr. Wolfe
      • Jul 2014
      • 540
      Originally posted by rcsoundn1
      no its not why.
      Go on.
      Mr. Wolfe
      • getouth
        • Jan 2010
        • 3343
        People stretch it because of the poke and stretch revolution........?? not into that myself but whatever. Choices in 16" have been getting slim for the last few years. Even the most basic ford focus or Toyota corolla now comes from the factory with 17" wheels.
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • bumada
          • Apr 2015
          • 305
          Mr. Wolfe
          I ran into this same dilemma with my 16x8 and 16x9 setup. I ended up just doing a 215/45/16 on the front and backs. The fronts look good but the rears are stretched a bit. When you looked at different sizes, you couldn't get the same tires or even close to the same tread rating.
          1989 325i S50 swapped
          2007 4Runner Sport V8
          • Mr. Wolfe
            • Jul 2014
            • 540
            That seems to be the case. I even thought about going 17", but I think they look a tad big on the e30.
            That is what I am finding. Do you happen to have any pictures of your setup?
            Mr. Wolfe
            • bumada
              • Apr 2015
              • 305
              Mr. Wolfe
              Sent from my SM-G900V using Tapatalk
              • Mr. Wolfe
                • Jul 2014
                • 540
                Thanks for the pictures. I can deal with that amount of stretch, but not more.
                Mr. Wolfe
                • bumada
                  • Apr 2015
                  • 305
                  Mr. Wolfe
                  Didn't you used to have a white integra and was frequent on vadriven back in the day?
                  • Mr. Wolfe
                    • Jul 2014
                    • 540
                    Nope, someone else. I had a few is300's back in the day and have been pretty much exclusively on the m3forum for the past 10 years.
                    Mr. Wolfe
                    • AwakenNoMore
                      • Dec 2010
                      • 1291
                      I've gone up in diameter to 24.6" rolling stock, speedo is actually more accurate and tire sizes seem to be much more common. Currently running 215/45/17. (yes I know not as bad to find as 16's) Makes 17"s look less funny.
                      1991 325i - "Scambles" The Daily Driven lightly modded.
                      1988 Mazda RX-7 TII "Mako" The Free Dorito
                      bacon by Jared Laabs, on Flickr
                      • McGyver
                        • 4636
                        But wouldn't the contact patch be the same for both wheels, essentially defeating the purpose of running a wider tire in back?
                        • bumada
                          • Apr 2015
                          • 305
                          Mr. Wolfe
                          Just did some research, his username was J.Wolfe. Sorry about that.
                          • Mr. Wolfe
                            • Jul 2014
                            • 540
                            Originally posted by AwakenNoMore
                            I've gone up in diameter to 24.6" rolling stock, speedo is actually more acccurate and tire sizes seem to be much more common. Currently running 215/45/17. Makes 17"s look less funny.
                            I need to research this some more. What is stock rolling diameter? I guess I could look that up...
                            You are correct, but I don't think everyone goes with a staggered setup for more tire, but for better aesthetics. Fatter lip, more concavity, etc. I struggle with this as I do like that look, but I am contemplating just doing a 16x8 all around.
                            Mr. Wolfe
                            • bumada
                              • Apr 2015
                              • 305
                              Essentially unless it's for looks. I'm going a different route once I finish my s50 swap.
