Who makes the best Poly bushings/mounts?
  • flyboyx
    • 8371
    I have been looking at the AKG 70a black poly mounts/bushings. i definitely want mild street use components that are somewhat better than stock. i don't want crazy nvh.
    akg's engine swap mounts are pricey at 200.00 a set, but are they worth it? has anyone had failures?
    any other brands that members have had good luck with and meet my criteria?
    Gigitty Gigitty!!!!
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    I have The revshift motor mounts these
    http://www.revshift.com/product-p/pmm-e30.htm
    i have the blue 80a mounts for motor and trans, They aren't bolt though mounts which keeps the NVH down.
    I will say the trans mounts did add some vibration but its not as bad as other cars I've been in with solid bolt though mounts.
    i also have redshift full street rear bushing kit with I'm pretty happy with. I wish i would have gone with the camber compensation subframe bushing but i can always pull the subframe again.
    88 325is Five Speed
    Lachssilber
    • stonea
      • 2892
      I've always heard AKG is the best. I was going to go with revshift until I heard about the customer service nightmares.
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • e30m3s54turbo
        • Jun 2010
        • 3290
        S62 vert m3 Alpina. Not sure it will work for you??????
        • flyboyx
          • 8371
          oh, its gonna work. even if its by shear force of will. i'll have the hard top on it most of the time anyway. i just want to carefully select parts that are going to handle 400hp.
          i was just thinking that i haven't talked to you in a coon's age. how have you been?
          Gigitty Gigitty!!!!
