Engine Porn
  • Preyupy
    • Oct 2012
    • 73
    #241
    You are correct, Supercharged engines benefit very little from "tuned" exhaust headers. With a bit of cam overlap they do a good job of clearing the cylinder of exhaust gas all my them self.
    • LJ851
      • 7918
      #242
      Originally posted by LateFan
      I don't even know what this is...
      A V12 using chevy LS architecture and some parts. It's fired like 2 V6's nose to tail as opposed to the more traditional 2 inline 6's side by side. Australian company i believe.
      Lorin
      The M30 is God's engine.
      • lukeADE335i
        • Apr 2013
        • 1385
        #243
        Yes - they started out chopping up two LS blocks and welding them together for their prototype, now they are getting new custom blocks cast.
        A set of petrolhead brothers, Matt and Shane Corish from Australia, hatched an ambitious plan to construct a V12 LS engine on a production scale.
        My e30: OEM+ with M30B35
        • LateFan
          • May 2013
          • 4399
          #244
          1921 Alfa Romeo G1 straight 6
          Not sure if that's a provision for twin-plugs...?
Name:	1921 Alfa Romeo G1.jpg
          • CurrusDei
            • Mar 2014
            • 673
            #245
            _______________________________________________
            5 Year M3 Build, In Progress
            RMT200 Retrofit
            • LateFan
              • May 2013
              • 4399
              #246
              http://www.enginelabs.com/news/video...ts-u-s-shores/
              That's quite a motor. I'd like to see the jigs they had to fabricate to cut / align / weld these with.
              In that piece, he says the block can handle 1000hp, and it's at 717 now with a very mild tune. By the time people start messing with it, 300hp is not a lot of headroom. Maybe the newer cast blocks have some improvements for strength.
              Do you know if there's any licensing problem with casting essentially a copy of "most" of a GM part?
              • Archr0y
                • 7
                #247
                • flyboyx
                  • 8371
                  #248
                  would that be as s10?
                  Gigitty Gigitty!!!!
                  • JimmyP
                    • 394
                    #249
                    I think it was called the M12 (which must pre-date the M engines as regular ones and S engines as motorsport engines?)
                    BTW - That S14 is beautiful! Inspirational even.
                    Jimmy P.
                    87 E30 M3 Prodrive British Touring Car
                    88 E30 M3 Zinnoberot - Garage Queen
                    88 E30 M3 Lachsilber - SCCA SPU #98
                    92 M Technic Cabrio - S14 Powered!
                    98 318Ti Morea Green
                    04 Ford F350 Dually Tow Machine
                    • Preyupy
                      • Oct 2012
                      • 73
                      #250
                      By then the official engine designation was M12/13/1
                      • LateFan
                        • May 2013
                        • 4399
                        #251
                        [ATTACH]118320[/ATTACH]
                        [ATTACH]118321[/ATTACH]
                        [ATTACH]118322[/ATTACH]
                        [ATTACH]118323[/ATTACH]
                        • LateFan
                          • May 2013
                          • 4399
                          #252
                          Disclaimer: I don't know anything about Toyota engines.
                          This guy took two 1JZ straight six engines from JDM Supras, cut them up, and welded them together as a turbocharged V12.
                          It's in Road & Track.
                          "So without doing much in the way of investigation or measurement, Groff picked up twin 1JZ engines yanked from early-’90s Toyota Supras, cut the blocks just above the oil pan gasket surface, and scratch-built a new crankcase out of TIG-welded 3/4-inch steel. “Where I got lucky is the head bolt pattern is symmetrical,” Groff tells me. “You can flip the head end-for-end. There are 13 oil drain-back holes in the block. Those are what I used to bolt the cylinders to the crankcase."
                          He is apparently a metal wizard and this is a mock-up of what it's going into...
                          Sounds like this...
                          • CurrusDei
                            • Mar 2014
                            • 673
                            #253
                            Engine Porn
                            Thanks. I have to split the credit with Korman. They did a magnificent job on the rebuild. I sourced parts and did some of the plating. Inching closer to putting her back in.
                            RMT200 Retrofit
                            • Court M3
                              • Jan 2004
                              • 6713
                              #254
                              That s14 is just simply beautiful...Makes me want a poster to put on the wall
                              Continuous For Sale Thread
                              323i s50
                              • Habla
                                • May 2004
                                • 1470
                                #255
                                -Peter
                                318is slicktop | F15 35dM | F250 SD
