Engine Porn
  • LateFan
    • May 2013
    • 4399
    #256
    ^^ yes!
    • varg
      Florida Turbo Man
      • May 2014
      • 3350
      #257
      Old school cool
      Flathead with a Graham supercharger
      Miller 91, which I may have posted before.
      IG @turbovarg
      '91 318is, M20 turbo
      • LateFan
        • May 2013
        • 4399
        #258
        Millers are crazy cool.
        On that Flathead, what is the rubber line in the center of the pic going into the cyl head? Is there a water jacket around the intake?
        And what is driving the supercharger?
        • varg
          Florida Turbo Man
          • May 2014
          • 3350
          #259
          Charge cooling, it must have been a very inefficient compressor for coolant temperature to be lower than charge temperature at such low boost levels (the hoses on the heads are coolant outlet, not inlet!). It's belt driven through a 90 degree gearbox. I just realized that that picture was mislabled and it's a McCulloch, not a Graham supercharger. Here's a good picture of one:
          And if you have a look at the compressor wheel you'll see why it was so inefficient. Very primitive, as you'd expect from a pre-war supercharger. https://bangshift.com/bangshift1320/...-supercharger/
          IG @turbovarg
          • LateFan
            • May 2013
            • 4399
            #260
            Matra V12
            These old F1 cars ...look at that thing - he has a bit of plastic or aluminum around his upper body, but he's just sitting in a shallow tub with no protection. The roll hoop doesn't even reach to the top of his helmet.
            • KrautnotRice
              • Feb 2015
              • 406
              #261
              Incredible. You really didn't wanna crash in those.
              Brass balls.
              '93 300TE 24V Krautbomber
              '84 528e 5 speed Saphirblau Metallic [R.I.P.]
              I love all BMWs with round headlights!
              • TobyB
                • 5213
                #262
                The CanAm F5000's were at the vintage races a few years back, here-
                4 huge tires, a bit of conduit, and a 5 liter v8 in behind you.
                It scared me just watching the engine twist the 'frame' at idle.
                t
                • lukeADE335i
                  • Apr 2013
                  • 1384
                  #263
                  Originally posted by KrautnotRice
                  OLD F1 CARS - Incredible. You really didn't wanna crash in those.
                  Brass balls.
                  Indeed - the bare V12 sounds amazing. Max Vestappen probably wouldn't be alive by now if he were racing in that era with the season he's having thus far!
                  My e30: OEM+ with M30B35
                  • Preyupy
                    • Oct 2012
                    • 73
                    #264
                    The coolant running through the supercharger housing was not for "cooling" it was to keep the supercharger from icing up. In a draw through application where there is fuel in the supercharger the temperature drop is so high that it will actually freeze up (even worse in cold, damp weather). If the fuel condenses inside the supercharger it will puddle and if there is a back fire it will blow the supercharger off the engine. Early European SC cars had blow off valves in the intake track just for this reason, it was not for limiting boost it was to keep from blowing the thing UP.
                    • LateFan
                      • May 2013
                      • 4399
                      #265
                      ^^ That's crazy talk!....and really interesting - thanks!
                      • LateFan
                        • May 2013
                        • 4399
                        #266
                        On the Matra F1, can someone explain the three sets of 2-into-1 headers on each side? Is that a scavenging thing? Similar idea to a 180ยบ header on a V8?
                        • LateFan
                          • May 2013
                          • 4399
                          #267
                          [ATTACH]121449[/ATTACH]
                          • LateFan
                            • May 2013
                            • 4399
                            #268
                            bump
Name:	Dirk Schumann's AutoDelta.jpg
