Mess under the intake delete, Addt'l thermostat delete, Mystery carpet stain help!
  • Nürburgring
    • Jan 2016
    • 87
    1991 BMW 318is.
    I'm currently working on the "mess under the intake" delete found on the M42 forum. While replacing hoses I came across a post-production item known as the "additional thermostat" that links the intake to the output hoses that lead to the heater core from the engine. I've tentatively chosen to delete the "additional thermostat" as I believe mine is faulty and don't want to replace it for $50 and clutter up my engine bay since the whole point of the hose delete is to get rid of any unnecessary plumbing. Some have mentioned that if the engine overheats, the thermostat's job is to keep excessively hot water from entering the heater core which could cause it to 'explode' and spray scalding hot water all over the driver's legs. Yikes. I must be brave...or dumb...for wanting to delete it.
    In any event, if any of you have done this delete, please let me know how it worked for you or if it backfired and you ended up putting it back on later (not something I want to do).
    As a side-note...can anyone explain this stain on my passenger side carpet? I want to say I've seen other E30s with a similar stain. What the heck is this from? Perhaps the heater core DID explode in the past? Maybe the stain is related to why this car was retro-fitted with the additional t-stat? I need your wisdom!
    Video explaining the issue:
    https://www.youtube.com/watch?v=CXLA...ature=youtu.be
    Photos of the carpet stain:
  • Chinampa
    • Jul 2013
    • 247
    I wouldn't get rid of it since it is a BMW recall item and heater cores exploding are a real threat..
    - 90 325is
    • biodose
      • Jun 2015
      • 145
      Personally, I've owned 5 E30's since 2004 and none of them have had it. I've also never heard of a heater core exploding. But, it's ultimately up to you.
      Support my E30 addiction! Buy my Wideband/Voltmeter Check Panels
      HERE
      1990 Flachalpinweiß 335i
      • Nürburgring
        • Jan 2016
        • 87
        You guys literally sound like the devil on my left shoulder :devil: and the angel on my right shoulder !
        I want to leave it in but I also want it out!
        Can't someone just make up my mind for me! I feel like if these things were exploding all over people's legs on the regular...there'd be a lot more on the internet than the one or two threads I've seen related to the topic. I realize I'm taking a risk...
        There will be times when I run my car hot as I'm planning to partake in at least 8-10 autocross (aka Solo) events this year...and I enjoy a good romp on the highway periodically or up to Lake Placid through the Adirondacks.
        • 5Toes
          • 9836
          the stain actually looks like it is from a heater core leak lol, that's the only place really that a stain like that can come from. The console is a breeze to take off so Id do that and take a closer look
          the thermostat you want to delete is to make the car idiot proof. If you watch your temp gauge than youre not gonna have any problems...
          • Nürburgring
            • Jan 2016
            • 87
            Will do, 5toes. thanks!
            • AndrewBird
              The Mad Scientist
              • 11898
              This.
              Don't excessively overheat your car and you won't have a problem.
              • jhaurimn
                • Nov 2012
                • 2224
                Make sure the elephant drain hose isnt clogged. When mine was clogged, I had water come out from that exact spot.
                You can also smell it to see if its coolant or water.
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • Nürburgring
                  • Jan 2016
                  • 87
                  By elephant drain hose do you mean the one going from heater core to pipe with four ends on it...or the hose the heads back to the bottom of the radiator? Or neither of those?
                  • 5Toes
                    • 9836
                    elephant drain hose is gonna be on the firewall on the passenger side of the valve cover, its flat black and about 1 inch wide by 5 inchs long. they clog up with pine needles, leaves, etc. and the water has to find another place to dump.
                    • Nürburgring
                      • Jan 2016
                      • 87
                      Had no clue!! Thank you very much. I'll check it out.
                      • RoyalW/BlauCheese
                        • Dec 2015
                        • 126
                        Heater core leak or heater valve leak. Had mine take a shit on me a month ago leaked from the same spot.
                        _____________________________________________
                        1987 325
                        • Nürburgring
                          • Jan 2016
                          • 87
                          What was your solution? Replace heater core? Just valve? Both?
                          • Nürburgring
                            • Jan 2016
                            • 87
                            http://www.realoem.com/bmw/enUS/show...diagId=64_0087
                            Is this the elephant drain hose? #5?
                            • 5Toes
                              • 9836
                              yes that sure is. mine crumbled in my hands and came off in a few pieces, im pretty pissed its a $25 part now but its whatever I guess... for the time being my car is sitting without one lol
                              good job using realoem! I prefer bmwfans.info but its all the same anyways..
