Do we have an MTech 1 Thread?
  • bradnic
    • Jul 2012
    • 3554
    #181
    Details on the Metlzer part numbers on my coupe sideskirts - last bit is the mold date I assume. the numbers all match JMs
    30 year old parts yo!
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • 2002jm
      • Sep 2005
      • 2077
      #182
      thanks
      Ok, I do not have vert skirts:). Will find out in the next few days if the driver side will go on easier by putting the back on first.....if it does will have to take the passenger side back off:(.
      Which is all part of the learning process...right:)
      Thanks for the pictures and help.....got the euroweaves on the car 15", so it looks so much better.
      jm
      • Old city bimmer
        • Jun 2014
        • 1114
        #183
        These are mines
        323i MTEC1
        Z3 coupe
        E60 M5
        • Old city bimmer
          • Jun 2014
          • 1114
          #184
          All glass out and absolutely no rust for 31 yr old window frames. Car is going to the paint shop tmrw. It will take a month.
          323i MTEC1
          Z3 coupe
          E60 M5
          • Mr. Wolfe
            • Jul 2014
            • 540
            #185
            Can't wait to see some new pictures!!
            Mr. Wolfe
            • 2002jm
              • Sep 2005
              • 2077
              #186
              side skirts
              Well, I confirmed, at least on my car, the back of the skirt goes on first and then the front and then the middle part. Guess the front is more flexible and will 'bend' around the wheel well better than the back. Here are a couple of pictures. Now to take the rear valance off again and fix the brackets:)
              jm
              • Old city bimmer
                • Jun 2014
                • 1114
                #187
                What did you use to mount it on the fender wells ?
                Sent from my iPad using Tapatalk
                323i MTEC1
                Z3 coupe
                E60 M5
                • 2002jm
                  • Sep 2005
                  • 2077
                  #188
                  used the same screws that are used to mount the clips down at the bottom. They are about 1/2" long.
                  jm
                  • Old city bimmer
                    • Jun 2014
                    • 1114
                    #189
                    Oh Ok-So what is the blk spot I see in the pic. A grommet or a cover ?
                    I forgot to send you pic of the clip they use on the factory set up. They use rivets to attach it to the wheel well.
                    323i MTEC1
                    Z3 coupe
                    E60 M5
                    • bradnic
                      • Jul 2012
                      • 3554
                      #190
                      JMs pics inline
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • 2002jm
                        • Sep 2005
                        • 2077
                        #191
                        When I drilled the hole, a chip of paint came off, so I have to fix that. That is a 8mm hex screw that you are looking at.
                        jm
                        • Old city bimmer
                          • Jun 2014
                          • 1114
                          #192
                          What are you doing to prevent rust from starting ?
                          323i MTEC1
                          Z3 coupe
                          E60 M5
                          • 2002jm
                            • Sep 2005
                            • 2077
                            #193
                            Going to get some por-15 and go over everything I have drilled into this summer.
                            jm
                            • Old city bimmer
                              • Jun 2014
                              • 1114
                              #194
                              I've been using etching primer and then epoxy primer
                              323i MTEC1
                              Z3 coupe
                              E60 M5
                              • 2002jm
                                • Sep 2005
                                • 2077
                                #195
                                yes, that is the way it is suppose to be done:)
                                Have to take my rear valance back off and then fix the brackets....drill some holes and use the primers like you did. My valance is sitting about 1/2" too low:) and I need to cut the rear end caps so they fit the m-tech kit. Then I will work on the inside of the car:).
                                jm
