ODOMETER isnt working.
  • ddongbap
    • Sep 2005
    • 248
    It just stopped one day. The trip meter dosen't work either. Don't worry. The chassis is shitty condition, and I'm not gonna try to sell it. It's going to be scrapped once I find a better chassis.
    Could anyone be so kind enough as to explain to me where the odometer/trip meter is connected? Tranny? Back wheels? Tranny huh? And any solutions?
    My drinking team, has a racing problem.
    Anyone have an aquarium? If you want fish, let me know.
  • FredK
    • 14763
    Does the speedo still work? If so, it's probably not the speed sensor, which is hooked up to the back of the differential.
    If only the trip and odo aren't working, check the SI board batteries. Remove the cluster and check the gears to see if they're missing teeth or are broken.
    Check out the fix for a jumpy speedo and nonfunctional trip and odo.
    • silverblades181
      • Nov 2004
      • 222
      check the fuse, and check if your back-up light works. Happened to me before. The wire for the back-up light got unhooked from the shift linkage and rubbed against the drive shaft which broke it. It shorted on the drive shaft and blew the fuse. The odometer and trip meter are wired with the same fuse. Could be this.
      E30 325i 1990 (Winter beater)
      E36 M3/4/5 1997 (Futur IP car?)
      BMW Club of Quebec
      • ddongbap
        • Sep 2005
        • 248
        WOrd. Ill do this tonight.
        • 808BMW
          • 2910
          Your speed sensor is probably fine. The plastic gears inside the cluster are prone to breaking, and thats probably what happened. I have like 5+ clusters, all with broken gears.
          odometergears.com if you want to fix it, but I did that and it just broke again, not really worth the hassle (unless milage is THAT important to you, it isn't to me)
          • Digitalwave
            is a poseur
            • 6299
            It's most likely the gears as stated before, I've gone through 3 of them.
            RISING EDGE
            • netcsk
              • Apr 2004
              • 1609
              you replaced all of the gears and it broke again? I find that unlikely. I suspect you only replaced one and then another one of the old brittle ones fell apart.
              • Digitalwave
                is a poseur
                • 6299
                Different speedometers.
                RISING EDGE
                • PiercedE30
                  • Apr 2005
                  • 4220
                  how good are the BavAuto gears? I know some people don't like the gears from odometergears.com because they break after a few months or something.
                  My 2.9L Build!
                  • ddongbap
                    • Sep 2005
                    • 248
                    Well I guess it isn't important. Its just I used my odometer as a gas meter, since my actual gas meter isnt working. I just need to get one, or the other fixed.
                    • ddongbap
                      • Sep 2005
                      • 248
                      BTW, there were two wires above my tranny. They entered my cabin through the rubber shifter boot. Does anyone know what this is? My drive shaft tore it appart. I fixed it today, when I removed my harmonic balancer.
                      • Digitalwave
                        is a poseur
                        • 6299
                        Reverse light switch.
                        RISING EDGE
                        • CleanAzzE30z
                          • Jan 2004
                          • 11794
                          My odo (on the eta) stopped working at 212K and on the way to Bfest '06. Bullshit if you ask me. How does one solve this problem?
                          Mariano
                          • silverblades181
                            • Nov 2004
                            • 222
                            yeah those are the reverse light wires. My bad I mixed up odometer and tachometer....nevermind what I said. It's probably the gears like they said.
                            BMW Club of Quebec
                            • DaveInLA
                              • Apr 2005
                              • 222
                              This sounds intriguing. My odo and trip stopped working (though they'll work intermittently), but the speedo is fine. I tried taking out the cluster and all the gears look fine. If I turn one with my finger, they all move and the odo will move along with them. I think the problem is electrical, which is why it will work once in a while.
                              What fuse are you talking about? Can I access it through the fusebox?
