AC low pressure line question??
  • fresh_TD
    • Aug 2013
    • 2457
    Is the low pressure AC line not offered with the R134 fitting like the high pressure line is?
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • Exodus_2pt0
    • 5943
    Not quite what you were asking, but they make adapters.
    No E30 Club
    • fresh_TD
      • Aug 2013
      • 2457
      http://www.r3vlimited.com/board/showthread.php?t=232161
      There are 2 hard lines, high pressure which connects to the dryer, and low pressure which connects to the compressor. The high pressure line you can get with the R134 fitting from a late model e30 '92+.. but I couldn't find the same for low pressure line.
      • Das Delfin
        • Sep 2014
        • 2293
        it's grayed out on realoem.. number 8 in the diagram showing all the A/C hoses.. which means I have no idea!
        • roguetoaster
          Biggus Tippus
          • 7826
          Thought it was the other way around with H/L lines?
          Anyway, when I did mine, I did not have to replace lines, but I did the drier & compressor. The new drier comes with one less fitting, which is where the H (IIRC) fitting was originally. As it is now the pressure switch takes this single port, and to charge/evacuate the system it's necessary to remove the pressure switch/jump the compressor as needed.
          • Das Delfin
            • Sep 2014
            • 2293
            ^ no, he's right about the H/L sides. It seems backwards
            • fresh_TD
              • Aug 2013
              • 2457
              You're saying the pressure line that connects to the dryer is low pressure?
              • fresh_TD
                • Aug 2013
                • 2457
                Rogue, I did all that.. there's a line I need to replace because it leakes, so I just wanted to add those 2 (r134) lines.
                • fresh_TD
                  • Aug 2013
                  • 2457
                  Guess I wasn't looking hard enough! found what I was looking for.
                  http://www.realoem.com/bmw/enUS/show...diagId=64_0529
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    It's really not recommended to jump the compressor to charge an empty system for obvious reasons. The LP switch is set for 25lbs and if you do a static charge...meaning with the car not running, the pressure should rise to ambient temp and be equal on both sides of the gauge.
                    It may take a few minutes to balance out but that should close the LP switch as well as provide some lubrication for the compressor
                    Alice the Time Capsule
                    • roguetoaster
                      Biggus Tippus
                      • 7826
                      The procedure followed, that seemed to yield good results was, vac system, wait and see if there was a pressure drop, charge by weight (30lb can on scale), turn car on, test system, remove switch, reconnect, jump switch and complete charge. A bit of an annoyance with the new drier setup and conversion to single pressure switch, but totally workable in my case.
                      • Das Delfin
                        • Sep 2014
                        • 2293
                        ^ wait have other people had to charge their cars like this? Seems counter intuitive
                        • roguetoaster
                          Biggus Tippus
                          • 7826
                          No idea, but without a second port or a tee off of the drier youre SOL as far as standard charging goes. However, I did not convert to a parallel flow condenser, or replace my lines despite the potential for leakage. I was only out to make my AC work before hot weather hit, and without breaking the bank.
                          Maybe as fresh_td was saying about lines, perhaps there's one on the drier side with a fitting.
                          • Das Delfin
                            • Sep 2014
                            • 2293
                            I think I see what you're saying. You're saying you charged it at the dryer? Instead of using the schrader high and low valves near the passenger shock tower and near the hood hinge
