DOHC Camshaft Install Questions
  • marshallnoise
    • Sep 2013
    • 3148
    I have gotten my m60 (similar to m42 or m44) heads back from the machinist and I need to reinstall the camshafts. He told me its a good idea to use assembly lube so I will. Not worried about that and neither am I worried about timing. I have the cam timing tools and copious pictures to show me the right orientation after the caps are reinstalled.
    When I removed the cam shafts, I was able to do so by very slowly loosening each cap nut by a 1/4 turn each. You can clearly tell where the cams are under pressure.
    When reinstalling, should I go to the effort to get the valves opened and held open? Or just very, very slowly do the same as I did when removing the camshafts and hope for the best?
    Thanks for the suggestions.
    Si vis pacem, para bellum.
    New Hawtness: 1995 540i/6 Claptrap
    Defunct too: Cirrusblau m30 Project
    Defunct (sold): Alta Vista
    79 Bronco SHTF Build
  • Varinn
    • 780
    For what it's worth, I disassembled and reassembled my S52 cylinder head with the 1/4 turn method and it all worked out great.
    I used this video as a reference for the process. Skip to 19m44s
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
    • marshallnoise
      • Sep 2013
      • 3148
      That's a great video. Thanks for sharing that! It gives me more confidence.
      • e30onBBSs
        • Dec 2014
        • 1347
        Tighten the middle first and then go from side to side working your way to cylinder 1 and 6
        BMW tech
        Umass Amherst
        05 wrx sti
        • Dj Buttchug
          • Jun 2010
          • 7688
          I usually articulate the cam so that only 1 or 2 sets of lobes are going to compress valves and I start adding the keepers. You want to make sure it has the least amount of stress possible. After I get it torque'd then I rotate the cam into the position I want to set time.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • marshallnoise
            • Sep 2013
            • 3148
            Thanks!
            Cool. I noticed that when I was pulling out the cams they were pretty much in that state (least amount of stress). Plus that's logical. I am fortunate that my cams are only 4 pistons wide instead of 6.
            • mrsleeve
              • Mar 2005
              • 16390
              just dont lose your oil cap and use a sock for a replacement, it might end up dry and stuffed up in your crankcase
              Originally posted by Fusion
              William Pitt-
              • marshallnoise
                • Sep 2013
                • 3148
                Lmao
                • mrsleeve
                  • Mar 2005
                  • 16390
                  did you not see the troll threads from earlier
                  William Pitt-
                  • marshallnoise
                    • Sep 2013
                    • 3148
                    Oh I did and they were epic. Well, 8/10. But you caught it right away.
